Manual Transmission hard to shift sometimes
Old Aug 17, 2022 | 05:58 AM
Kiju's Avatar
Question Manual Transmission hard to shift sometimes
Hey!
| Honda Fit GK 2020 5-speed MT | All stock | 12,500 miles/ 20000 km | bought it at 12,000 miles |
As the title says but it is usually when shifting from a stop; N -> 1 and N -> R. I always have to press the clutch 1 to 2 times before it engages. Not all the time though. I'd say 1 out of 5 it happens.
I've checked my gear oil and it looks fine. What could be the problem? or is it a problem with honda fits? I've read a review on honda fits especially gk and there's always this problem.
Thanks!
Old Aug 17, 2022 | 06:31 PM
newengland72's Avatar
You’re on the right track
As a Honda Fit owner who has had theirs 9+ years, I change the transmission fluid(with AMSOIL Synchromesh) every year, or every 20,000 miles whichever comes first. The synchros are notoriously weak and finicky, and at least in my Fit, the fresh fluid really helps keep the trans feeling slick.
Old Aug 18, 2022 | 11:30 AM
Mister Coffee's Avatar
Like @newengland72 said, change the MT fluid. I use Honda MT Fluid.
Old Aug 18, 2022 | 08:05 PM
BMWguy22's Avatar
I also suggest changing the fluid ASAP. I swapped to Royal Purple Synchromesh.
"Amazing" would be an understatement.
As others have mentioned with these cars, the trans doesn't shift from N>1 usually very easily.
A way I've found to alleviate the additional force required to get the shifter into gear, would be to let off the brakes and let the vehicle roll a few centimeters forward OR backwards.
While it's rolling, you apply light pressure to the shift lever and it'll always "plop" into gear.
Works everytime!
Old Aug 18, 2022 | 11:09 PM
Time for a new skill
BMWguy22 has an excellent point; I often blip the throttle with my transmission in Neutral and the clutch out when trying to get into 1st or Reverse. This causes the synchros to spin and helps get the ready to get into those tough gears.
Best of luck
Old Aug 19, 2022 | 01:44 PM
GrE8_Fit's Avatar
I had to do that little 'double clutch' dance before changing my MTF. I used Honda OEM and it's better, but not amazing. I will definitely be trying Royal Purple next time. So expensive, though.
Old Aug 19, 2022 | 03:46 PM
Just one
I used to feel the same way, but then after changing it a few times, I figured out that it only takes one quart. Every time I tried to put the second quart in, it would just run over. So now I only buy one quart. Still $30/qt AMSOIL Synchromesh from Amazon but for only once a year not a real big deal.
hidor02
Mar 27, 2022 12:01 PM
1speedbike
Jul 13, 2015 10:01 PM
nicco
Sep 29, 2014 11:11 PM
hayden
May 27, 2010 09:10 PM
jdjohnson9
Nov 13, 2007 08:59 PM
