Replacing A-Pillar clips
Old Nov 25, 2022 | 10:01 PM
s1337m's Avatar
Planning on popping off the A-pillar in a 2016 to run some dashcam cables. What clips should I buy in order to replace?
Looking at: https://www.hondapartsonline.net/v-2...pillar-garnish
I need one each of part 20, 21, and 22. Is this correct? Any reason why part 21 is missing here?
Old Nov 26, 2022 | 08:13 AM
Action Jackson's Avatar
You can gently pull out the a pillar enough to run your wiring. You won't be able to completely remove that cover off because it's designed that way. There IS a way to remove it which involves some deliberate steps.
Old Nov 28, 2022 | 11:25 AM
woodenpickle's Avatar
I only had to replace one clip when I pulled mine for the same reason. Found a pack on Amazon.
It looked like this:
Sonnington
Mar 10, 2022 11:39 AM
FTBT
Jun 30, 2019 08:38 PM
evanphi
Feb 20, 2019 04:05 PM
classact2575
Apr 26, 2017 03:29 PM
jade
Jun 8, 2015 12:48 PM
