How to fill in spare tire space?
Old Jan 2, 2023 | 07:51 PM
Zackp's Avatar
This might sound dumb but I don’t have a tire there and I live in a huge area I can instantly get a new tire on it. I have amplifiers and drums and I find it causes the area to sink in. I think it’s causing some creasing and probably some other issues. I don’t want to completely break that part as a small part definitely snapped. What do you use to fill the space? Or what can you buy to retrofit over it that would be stronger? If I have all my amps and drums it’s probably like 200 pounds max?
I admit I should have thought about this sooner and taken better care. But honestly the car takes a pretty good beating. I don’t plan on returning it when the lease is up (this July) as it’s not worth getting anything else!
Old Jan 2, 2023 | 08:56 PM
Drew21's Avatar
Plywood is the obvious answer. You can use the current spare tire cover as a template. My dad (a mechanic) has done this in every hatchback he's ever owned so that he can carry tools/toolboxes, tires, wheels, etc.
I'm not sure what thickness you want, but I think 3/8, 1/2, and 3/4 inch are available at Lowe's or similar. Obviously thicker is stronger, but also more expensive and heavier. You might be able to use a thinner piece of plywood with a few gussets screwed in to the bottom side.
Old Jan 2, 2023 | 10:37 PM
Action Jackson's Avatar
Old Jan 2, 2023 | 10:44 PM
woof's Avatar
Plywood... darn it someone beat me to it! Maybe 3/8" - the thinner the better because thick stuff can be a nuisance because of the high edges. Then try and keep the heaviest weights to the outer part of the trunk rather than the center if possible.
Old Jan 5, 2023 | 09:25 PM
2015FITEX's Avatar
just take the cover off,put a blanket down and use the extra space?
when i bought that car they said " wow..its a manual it has a spare tire"...im like "huh? i thought ALL cars had a spare tire " in canada the manual had a spare and the automatic didnt i heard......it that true in USA?
Old Jan 6, 2023 | 06:25 AM
awainer1's Avatar
Styrofoam. Read through the biggest loser thread on this forum. It’s a good one.
Old Jan 6, 2023 | 01:22 PM
GrE8_Fit's Avatar
Originally Posted by awainer1
Styrofoam.
Gross.....
Old Jan 6, 2023 | 03:05 PM
AirborneRATT's Avatar
I would consider 1/4" luan(sp?). Something like this maybe? https://www.lowes.com/pd/SurePly-1-4...4-x-8/50124674
It is flexible though so it may not meet your need.
Old Jan 6, 2023 | 06:21 PM
awainer1's Avatar
Originally Posted by GrE8_Fit
Gross.....
Why is that gross. Just grab a styrofoam block out of something u got shipped to u. It weighs nothing is the point.
Old Jan 6, 2023 | 07:52 PM
2015FITEX's Avatar
we need to utilize the underutilized spare tire space first to lower the CG
Old Jan 6, 2023 | 08:11 PM
BMWguy22's Avatar
That really makes no sense whatsoever.
Old Jan 15, 2023 | 01:57 PM
hasdrubal's Avatar
Hope this link will work, I made a plywood cargo floor with a hatch in it a while back.
https://www.fitfreak.net/forums/3rd-...ml#post1462362
cavernap
Dec 13, 2019 01:13 AM
Corvin
Jul 14, 2015 07:25 PM
Ultrawolf
Jul 29, 2010 02:24 PM
NEK FIT
Jun 30, 2008 07:52 AM
Martee
May 14, 2006 06:26 PM
