Oil leak
Old Feb 15, 2023 | 05:57 PM
FitCan's Avatar
Oil leak
Hi, New to the forum, her on behalf of an elderly family member who replaced a 2007 Fit with a 2019 Fit sport. Upon inspection for registration the mechanics discovered a leak, they suspect is the rear main seal. 2019 Fit Canadian model, made In Mexico92,xxxKm Automatic CVT Any ideas Thanks
Old Feb 19, 2023 | 09:42 PM
2015LXFIT's Avatar
I'm skeptical. It looks like you have oil leaking from above, a possible pan leak, and a possible RMS leak. Remove the black cover and you should be able to see inside to the rear of the engine. If under the flywheel you see wetness or even on, I'd look into a possible RMS.
Old Feb 20, 2023 | 08:49 AM
FitCan's Avatar
I've had two mechanics say rear main seal without being able to say definitively, it's going to Honda tomorrow for a recall. We'll see what they have to say. Hopefully it's covered under warranty.
Old Feb 20, 2023 | 10:27 AM
woof's Avatar
Let us know what happens.
Old Feb 20, 2023 | 11:49 AM
FitCan's Avatar
Sure, no problem.
Old Feb 21, 2023 | 07:59 AM
SkylineFTW97's Avatar
Looks more like transmission pan seepage than a rear main from that angle. If it is, should be easy enough to reseal it the next time the fluid is changed (if you're nearing 100k kms, then it should be due soon if not done).
For a rear main, it's not worth how much it costs unless it's a major leak. At 92000 kms, it's also about due for a new PCV valve. Sounds like yours might be going bad if it's getting leaks. If it's a minor engine oil leak, changing this will most likely slow it down to basically nothing. Way cheaper and more effective at stopping slow leaks.
Old Feb 21, 2023 | 08:30 AM
FitCan's Avatar
Thanks for the input. First mechanic did suggest pcv valve as a possible cause. With the car on the lift they did sort of narrow it down to the rear main seal, if in fact it's a seal at all as there was oil above the pan. Leak is diagnosed as minor, no drips below in a few days.Going in for the recall soon. We'll see.
Old Feb 21, 2023 | 02:49 PM
FitCan's Avatar
Back from Honda, they performed the recall. Cleaned the underside and let it sit, they don't see anything, said to come back in a week or 300km. It not being a major leak is good, but not knowing the source of the oil observed last week is concerning.
Old Mar 20, 2023 | 04:25 PM
FitCan's Avatar
Followed up with Honda a week after they cleaned the area. No sign of a leak. "Bone dry" they said. We'll keep an eye out periodically.
Old Mar 21, 2023 | 01:48 PM
Mister Coffee's Avatar
I wouldn't be surprised if it took more like 3,000 km to see something if it's a slow leak.
Old Sep 13, 2025 | 03:39 AM
Fitf's Avatar
Same oil leak. Need help
hi, i’m having the same leak, i also found some oil under the air intake housing, but oil doesn’t have any smell so I couldn’t tell if it was engine oil. Did the honda tell you where the leak was coming from? Thanks
Raddd
Nov 10, 2022 03:26 PM
Mister Coffee
Oct 31, 2022 08:44 PM
zacinnc78
May 29, 2021 11:09 AM
Joshua Meisl
May 26, 2019 01:12 PM
BLXFITTY
Sep 27, 2014 09:32 AM
