Changing key fob battery renders fob totally inoperable
Old Jun 30, 2023 | 08:40 AM
hartross's Avatar
Okay this has happened twice and I brought both fobs to the dealership to have them investigated, and they just made me replace them
But changing my battery renders my fob totally inoperable, and going back to the old battery doesn't fix it. The dealership couldn't remedy it so I'm turning to the real pros - has anyone experienced this?
I could bring it into the dealership for a batt swap but it's like $20. But they would do it and if it broke it'd be on them.
Old Jun 30, 2023 | 09:37 AM
NWCH's Avatar
Are you sure you are using the correct battery?
Old Jun 30, 2023 | 10:54 AM
hartross's Avatar
Yes, even the person at the dealership tried with a battery they supplied. Claimed id broken it
Old Jun 30, 2023 | 03:32 PM
Drew21's Avatar
I've changed batteries in key fobs from quite a few vehicles without any issues.
Sounds like something you did broke yours. I don't recall my Fit key fobs being especially difficult to pop open, but it's not hard to imagine how being aggressive could cause damage.
There are many instructional Youtube videos available. Even though I've opened up a bunch of key fobs, I always watch a video or two to refresh my memory on how they're supposed to come apart.
Old Jul 1, 2023 | 12:24 AM
Chitown Fit's Avatar
Broken FOB.
Sounds like you have a broken Key FOB.
You'll probably need a new one. And they're very expensive.
Old Jul 1, 2023 | 05:49 AM
nayov's Avatar
Does anyone know how much a new fob costs and where to buy one? I've only one and afraid it would be disastrous if I lost it.
Old Jul 1, 2023 | 07:55 AM
New Key FOB.
From the info I looked up prices are between $149.00 to $459.00
Old Jul 1, 2023 | 09:39 AM
woof's Avatar
FOBS can be bought (with the built in electronics) and cut (by providing them with a photo of your existing key pattern) for your car on AliExpress relatively cheaply but then you still have to get them programmed locally presumably by a locksmith who has the equipment and capability to do it.
Old Jul 1, 2023 | 11:52 AM
hartross's Avatar
Yes I did all this but I will try again. Can you confirm the battery that I would need for this is a 2032?
Old Jul 1, 2023 | 12:29 PM
Drew21's Avatar
What year Fit do you have?
My 2010 takes a much smaller battery. My Amazon order history suggests it's a CR1616, which matches this video.
Not sure how you would fit a 2032 in a 1616-sized hole, but doing so would likely cause some issues.
Old Jul 1, 2023 | 01:01 PM
woof's Avatar
My 2018 LX uses a 1620 battery. Anyways, make sure you don't put the battery in wrong side up.
Old Jul 1, 2023 | 01:48 PM
hartross's Avatar
https://www.youtube.com/watch?v=_eStku10qek
I have a 2017 manual
Old Jul 7, 2023 | 09:23 PM
howarejew's Avatar
I've had a customer come in with an inop keyfob after changing their battery. Turned out when they shoved the battery in they bent the metal contacts to where it was no longer making contact with the battery. Adjusted the metal contacts and all was good.
JDFit
Sep 9, 2022 02:25 PM
putneymountain
Jun 21, 2020 12:34 PM
JohnRaphael
Jun 27, 2019 01:58 PM
SilverEX15
Oct 6, 2017 05:39 PM
JFit123
Sep 22, 2014 05:10 PM
