2015 Fit ex manual timing valves both neither?
Old Sep 22, 2023 | 03:34 PM
FunkTastic's Avatar
2015 Honda fit ex manual 241k (highway only) miles
virtually no city driving
Engine has been making a loose rattling sound on cold startups for a while now. No one’s had an answer not even a dealership roughly 40 minutes from here.
this week about 30 minutes away from destination on a 4 hour (highway) drive the engine sound suddenly slightly changed but it still had same power.
next morning when starting and trying to rev to listen it went into limp mode and all the lights came on.
threw multiple codes,
temp misfire cylinder 2
too rich
and a few related to the fuel mix.
checked compression 3x on cylinder 2.
Ever so slightly low once and barely normal 2x
replaced spark plug and started fine but just sounded slightly out of time monitored misfires on scanner, periodic, random, higher than averages on cylinders 2 and 2 but highest on 2.
let sit a bit, still went into limp with cold start. It has to warm up then it will be ok full power but still sounds slightly out of time (just slightly to my ears).
After finding some videos that duplicate the long standing sound on cold, start up, I’m confident that it needs timing chain and components.
What are the chances that it would need a valve repair job as well? On anybody’s experience? It sounds literally just slightly out of time and I’m hoping this is a deciding factor.
Old Sep 23, 2023 | 08:25 AM
FunkTastic's Avatar
Thank you
I got an email with a reply posted here but I don’t see the post here for some reason so I’ll just post a thanks. I asked the dealership about the actuator and they said there’s nothing official and they didn’t seem willing to comp the parts and labor related to it. But it is what it is.
Thanks for the input and data
Old Oct 2, 2023 | 12:18 AM
2015FITEX's Avatar
ive had the loose rattling sound for years. we have pretty much the same car....54kkms always "heard" it wastn doing damage, possible fuel injectors?...in canada there is an extension to 10years on them with certain codes..
Old Oct 2, 2023 | 07:17 AM
FunkTastic's Avatar
We replaced the actuator and timing components. So far so good. Still has ha high number of live misfires showing on the scanner, imo, but it’s not feeling sluggish. Hopefully it’s ok
Old Oct 2, 2023 | 10:40 AM
woof's Avatar
Did you do a valve adjustment in addition to replacing things?
Old Oct 2, 2023 | 10:47 AM
FunkTastic's Avatar
We had a valve adjustment at 230k.
Brain Champagne
Feb 27, 2023 11:16 AM
dlogvine
Nov 23, 2019 07:22 AM
FunkTastic
Jan 27, 2019 09:26 AM
JeffreyAlan
Apr 1, 2018 02:31 AM
oiric2006@gmail.com
Sep 1, 2017 12:21 AM
