Reverse to Drive delay?
Old Sep 30, 2023 | 08:10 PM
Kirkland's Avatar
Hello,
I noticed that my 2019 Honda fit, automatic, has a slight delay engaging drive after switching gears from reverse. I usually swing reverse to drive pretty quick and go, but if I do it on the fit, it just revs for a second before engaging drive. It’s not instant but not a big delay, just noticeable enough to notice. I’m wondering if this is normal behavior?
Old Sep 30, 2023 | 10:33 PM
bargainguy's Avatar
Yes, it's completely normal. With the CVT, you're not allowed to shift into drive and have the gear engage instantly. It takes a second or two. The manual transmission is better at drop 'n go.
Old Oct 1, 2023 | 02:06 AM
Kirkland's Avatar
Thank you for confirming. Is this documented or acknowledged anywhere by Honda?
Old Oct 1, 2023 | 11:48 AM
woof's Avatar
I have never ever with any AT/CVT I have ever owned shifted directly from reverse to drive. I always shift into neutral first for a second or two and then into drive. I don't know why I once started doing that but I do believe that it might be damaging to the transmission. My manual does say:
"When you change the shift lever from (D to (R and vice versa, come to a complete stop and keep the brake pedal depressed.
Operating the shift lever before the vehicle has come to a complete standstill can damage the transmission."
Old Oct 3, 2023 | 08:00 PM
Kirkland's Avatar
Yeah, I don't shift abruptly either. I think with the AC at full blast there is an additional delay because I'm not noticing it as much with the AC off.
Old Oct 4, 2023 | 10:13 AM
Sham24's Avatar
You may need to change the transmission fluid. I began changing the fluid every 30k instead of every 50k per the maintenance minder, because after the first change, I noticed a huge reduction in the time to shift between P/D/R.
MsFit
May 21, 2015 12:56 PM
Stoli124
Apr 13, 2015 12:25 PM
8strung
Aug 15, 2014 02:49 PM
loud_tiger
Jun 25, 2007 12:05 AM
CRUnlimited
Aug 31, 2006 09:04 PM
