2015 Fit - Consistent groan from top of engine?
Old Mar 10, 2024 | 05:51 PM
RedRobin473's Avatar
Hello all. I have a 2015 Fit with 130k miles and the VTC actuator started making noise around 6 months ago and then a soft groan a month or so ago that remains the whole time the engine is running. I just finished replacing the VTC actuator and everything looked good while I was in there. Any other common issues that would make a soft groan that stays the whole time the engine is running that I should explore? I appreciate any insight you all have.
Old Mar 11, 2024 | 12:33 AM
2015FITEX's Avatar
alternator bearings ?
does it change when you turn the headlights on?
id love to hear your experience/advice on the DIY vTEC actuator
Old Mar 12, 2024 | 07:29 AM
All bearings on the front drive assembly seem fine and no change with headlights. It sounds like it is coming from the intake, pcv or perhaps injectors? Do they make noise when they have gone bad?
The actuator was a straight forward process. I followed the Honda service bulletin as a guide which was great as it had plenty of pictures as needed and the torque specs included.
Old Mar 12, 2024 | 09:11 AM
woof's Avatar
Could be a vacuum leak from a hose or hose connection. Or noise from a belt. You can buy stethoscopes for cars which may help pinpoint the source.
Flavlus
Jun 9, 2021 06:04 PM
jodfie
Dec 26, 2014 01:46 AM
bountybuddy
Dec 17, 2014 07:02 PM
exl500
Nov 20, 2014 04:47 PM
lapislazuli
Sep 13, 2014 10:21 PM
