Is this sound normal when turning wheels by hand?
Old May 6, 2024 | 01:58 PM
pfprojects's Avatar
Question Is this sound normal when turning wheels by hand?
Like the title states, I've gotten under the car to inspect things and to fix the splash guard. While I was down there, I turned the front wheels by hand and heard a clunking-like sound when doing so. I am just starting to learn how to fix my car, so this is a bit of an unfamiliar sound to me and I'm unsure if it's normal. I've taken a video of the sound. This is on a 2015 Honda Fit with 6 speed manual transmission. Thanks in advance for the help!
Also, I'm pretty sure my passenger-side CV axle boot is leaking. I will probably have to replace that soon :'(
Old May 7, 2024 | 09:56 PM
2015FITEX's Avatar
hmmm...you are taking up all the backlash so it might be ok......i assume no clackiny clackity while driving?..if all sounds good i wouldnt worry......but definitely keep an eye on it....does other side make same sound?
Old May 8, 2024 | 09:55 AM
woof's Avatar
I would have thought that there would be grease packed in there under the boot which would help muffle any sound.
Old May 28, 2024 | 10:20 AM
chocoboblue99's Avatar
Yeah, I'm pretty sure it's supposed to sound like that.
Old May 28, 2024 | 08:08 PM
2015FITEX's Avatar
i changed the snowtires last weekend, so i did this to my MANUAL trans and it doesnt sound like that. there is literally no noise when turning back and forth. so i had one wheel up,other on ground, if you had BOTH wheels up, maybe that makes a difference. unless there is clunks when actually driving it might last a long, long time, ....or not.,definitely i would monitor that.
Old May 28, 2024 | 08:34 PM
Chitown Fit's Avatar
CV Joint Replacement.
https://www.youtube.com/watch?v=geCXwCc2_Zc
You answered your own question.
Your CV Joint is shot.
You need a new CV Joint.
Old May 29, 2024 | 09:35 AM
woof's Avatar
Take it in to the dealer and get it evaluated.
abhijith
Jan 27, 2024 11:46 AM
allie_kat18
Oct 15, 2021 02:09 PM
FondatheHonda
Dec 12, 2018 07:54 PM
toomuchjoy
Jun 10, 2012 09:31 AM
FitRob07
Feb 25, 2007 04:36 AM
