2019 Fit base model heater dials malfunction
Old Oct 19, 2024 | 06:37 PM
leslind's Avatar
I'm having problems with heat controls. The dial that changes where air enters cabin seemed to stick. Then the dial regulating heat began sticking. Cables going from dial to control unit seem ok. I can't see anything interfering with the control units. Any suggestions?
Old Oct 22, 2024 | 09:15 AM
NWCH's Avatar
That is a known issue with the 3rd gen Fit now that they are getting a bit older. The heater box itself will need to be replaced.
The complete dash has to be removed to fix it. Not a cheap repair.
Old Oct 22, 2024 | 02:58 PM
leslind's Avatar
Thanks for the info. Even if it isn't the best info. I need heat before winter, so here goes for a repair at home, not a dealer shop.
Old Oct 23, 2024 | 09:20 AM
NWCH's Avatar
That really isn't a garage or driveway fix...
It's the evap or mix door that becomes locked or frozen over time. The only fix is parts replacement from Honda.
The same era Accords also have this issue.
Old Oct 23, 2024 | 10:38 PM
2015FITEX's Avatar
stop changing the dials....i change them one a year so as not to wear them out..but id try and DIY it before the dealer...sorry not more help
Amanda Luisa Rodriguez
Nov 24, 2020 02:23 PM
bourne1
Apr 22, 2017 04:07 AM
fitta
Dec 13, 2010 10:44 PM
cheapsterslady
Aug 1, 2009 01:04 PM
SlavetotheHonda
Jul 18, 2008 09:58 PM
