Bad Steering
Old Aug 21, 2025 | 09:48 AM
SilverEX15's Avatar
Bad Steering
A friend has a high mileage CR-V with bad steering. It was sitting for a while, and when she tried to start it, the battery was weak. It finally started, but the steering was erratic. Since it has electric steering, like the Fit, I'm guessing the weak battery caused that problem. Any other ideas?
Old Sep 22, 2025 | 07:23 PM
wasserball's Avatar
Once the car is started and running, the alternator supplies power to the electric power steering system. The alternator generates electricity from the engine's mechanical motion to power the vehicle's electrical components and charge the battery, so a healthy alternator is essential for electric power steering to function correctly. If the alternator is not working properly, it can cause the power steering system to lose power or become harder to turn, often indicated by a power steering warning light.
Old Sep 23, 2025 | 09:59 AM
SilverEX15's Avatar
Okay - problem solved. Her mechanic found that the fuse for the battery was blown, and the fuse box itself was fried. The mechanic repaired it and got it running. When she got it home, the radio wouldn't work, so I explained about the code for the radio. The radio now turns on, but there is no sound. The journey continues.
EMC2
Mar 25, 2017 04:45 PM
BixLives
Dec 21, 2011 10:12 PM
owner2009fit
Sep 28, 2008 07:25 PM
bobbied
Jul 9, 2007 04:19 PM
stony
May 4, 2005 11:16 AM
