Radio
Old Oct 25, 2025 | 10:24 PM
FitDeezy's Avatar
Radio
Alrighty i need the sauce for a new radio
I have a 2015 honda fit
i have the shitty one with the knobs *which nothing bad about the knobs i actually perfer it i just hate the tiny screen*
and here are the 2 things i want
#1 I WANT APPLE CAR PLAY
no shitty hong kong ebay 2 kilobytes of ram radio with *apple carplay* and when i gets here it has no n -_-
i want carplay,even if its the tiktok shitty kind i just want it, now #2
I WANT MY STOCK BACKUP CAM,
listen, i dont care really about putting in a camera but i dont want to deal with routing and wiring, i want a simple plug it in and stock camera is in use, so now with these 2 factors,, can i get any advice on this! thank you
Old Oct 26, 2025 | 12:53 AM
Chitown Fit's Avatar
LX Radio Upgrade.
That's a big ask for an upgrade from the stock LX radio.
Unless you're willing to spend thousands of dollars for this upgrade you're most likely SOL.
Old Oct 26, 2025 | 12:57 AM
FitDeezy's Avatar
yeah, fuck that then, i have an idea of what to do and i feel like its the cleanest anyone can do ill update this post whenever parts come in!
Old Oct 26, 2025 | 01:07 AM
LX Radio Upgrade.
Good luck to you.
Old Oct 27, 2025 | 10:01 AM
bobski's Avatar
Swap in a system from a newer Fit? Our 2020 EX stock radio has carplay.
Old Oct 27, 2025 | 10:30 PM
FitDeezy's Avatar
The thing is I’ve heard there’s a lot of differences so for example I found a radio on market place from a 2016 and Ik it dosent have CarPlay but I bought it for a bigger reverse camera,, all the plugs fit but there’s missing plugs maybe for options .. but sadly it dosent work, radio audio works but Bluetooth is inusable and the reverse camera as well. The radio thinks I’m in motion
Old Oct 28, 2025 | 12:00 AM
bobski's Avatar
There are pinout differences (wire locations in the connectors) between trims, probably between years. Unless someone has already done a write-up, you'll need to find the wiring diagrams for each car (yours and the donor car), then compare the function of each connector pin from one diagram to the other. Figure out what the new radio expects (donor diagram), then move the wires you have (your diagram) to the new positions. Most of them should be the same.
Old Oct 28, 2025 | 01:36 AM
FitDeezy's Avatar
im a bit slow im ngl, what do you mean?
all the wiring from my radio connects to the new radio but theres alot of missing wires,, assuming its a whole diffrent wiring harness,,
which to my knowledge theres no work around,, unless there is
Old Oct 28, 2025 | 01:41 AM
FitDeezy's Avatar
this is how the back of my radio looks like
and this is how the new radio looks like
Old Oct 28, 2025 | 09:11 AM
bobski's Avatar
With some fiddling (some connectors are worse than others), each wire can be ejected from the connector (called de-pinning) and plugged into a different location. The large plastic part of the connector is called the housing, the metal part crimped onto the end of the wire is called a terminal (aka the pin). To be honest, the more terminal-dense a connector is, the harder it is to de-pin. Modern automotive connectors typically have a locking bar (or bars) of some sort that acts as a backup retainer for all the terminals, then a flexible tang for each individual terminal which snaps in when the terminal is inserted in the housing. It's that tang that's a challenge to release. Look up "automotive depinning tool kit" to see the plethora of tiny tools to work the different connectors out there.
So I'll say yes it can probably be done (provided the PCM or gauge cluster or something doesn't outright reject it) but if you've never done an automotive wiring mod before, it's going to be a headache and then some.
Old Oct 28, 2025 | 01:37 PM
bargainguy's Avatar
There are various aftermarket options from the far east that offer carplay / android auto plus backup camera.
This one has a separate backup camera. It's unclear whether it hooks directly into the CANBUS or some other way.
Amazon Amazon
Old Nov 3, 2025 | 05:40 PM
Not Compatible.
Nope.
Won't work.
Just be happy with the radio already in your Fit.
TyJOrtiz
Sep 25, 2024 09:27 PM
Jan Coetzee
May 23, 2023 03:17 AM
xXWesleySevenXx
Jul 21, 2022 11:42 AM
Darlwy
Jan 9, 2019 10:33 PM
yellow wolf
Oct 24, 2015 05:51 PM
