Clicking Sound From Engine
Old Jan 18, 2026 | 09:24 PM
tomshanty's Avatar
Hi. I'm brand new to Fit Freak so I hope I'm posting in the right place. I have a 2015 Honda Fit LX and there is a clicking sound coming from the motor. I'll try to attach a clip of the sound. Any help is appreciated.
File Type: mov
Old Jan 18, 2026 | 10:30 PM
MTLian's Avatar
sounds like normal direct injector sound. I was concerned about my 2015 because my previously port injection 2007 fit did not make that sound. I had it checked by a Honda master tech and he said it was the direct injection.
there is however a bit of a knocking sound in the background. My 2007 used to knock when cold. I think that Hondas may just have a bit more clearance on the rod journals and when they warm up, it goes away. Never was a concern on my last Fit and that engine purred when it ran (along with sounding like a sewing machine with the valve clatter).
if the knock comes from the left side of the engine, you could have a pulley going bad. Probably not a huge concern until it gets really loud
im no Honda mechanic but your engine sounds normal to me.
Old Jan 20, 2026 | 10:05 AM
RidleySnowmere's Avatar
Klickgeräusche können viele Ursachen haben, daher ist systematisches Prüfen wichtig. Ich starte mit einfachen Dingen und mache zwischendurch Pausen mit Book of Ra Deutschland.
Old Jan 23, 2026 | 12:52 AM
tomshanty's Avatar
Thanks MTlian, I really appreciate the response. I did some more digging and googled fuel injector noise on the Honda Fit, and a bunch of videos confirmed you were right on the money.
I am planning to change my belt soon anyway, so when I do I will check the pulleys to see if any are loose or have dry bearings. Thanks again for pointing me in the right direction.
Old Jan 23, 2026 | 12:56 AM
tomshanty's Avatar
Originally Posted by RidleySnowmere
Sound normal to me.
Thanks man.
Old Jan 25, 2026 | 11:57 PM
MTLian's Avatar
glad it helped!
apparently there are positioning markings on the auto tensioner that shows if it is providing appropriate tension (with the belt installed) I don’t have a link but google it, it might help you determine if the tensioner is weak and needs replacing.
ralphch
Jun 20, 2010 11:03 AM
Mezzozero
Nov 4, 2009 10:46 AM
--Mike--
May 14, 2009 02:00 AM
TiMo
Jun 11, 2008 12:54 PM
ctxcrossx
Jun 12, 2007 04:55 PM
