Reverse Progress
Old Feb 21, 2026 | 01:50 PM
SilverEX15's Avatar
Reverse Progress
If any of you are using Windows 11, you probably realize that it's a step down from Windows 10. Everything seems to require more clicks to get things done.
It's the same with the Fit. If I want to reset the TPMS light in my 2015, I reach down and hold a button for a few seconds. I tried resetting that light on my son's 2020 this morning, and I gave up. I've done it before, so I know it's possible, but there are too many steps involved, and the final step didn't work.
Using the paddle on the right side of the steering wheel, I cycled through the choices till I got to TPMS. Then I pressed "Sel" to select it, but it didn't reset. It just moved to the next option. I tried this half a dozen times with no luck. At least I know the tire pressures are right.
Step 2, below, did not happen.
Old Feb 21, 2026 | 08:23 PM
2Rismo2's Avatar
Lol I have to agree. On my Fit to reset the miles driven when refueling was to toggle the knob and hold it down.
On my 2025 Ridgeline, I have to go hunting in the menu to do the same. Way more involved with the new vehicles.
Maybe one day we can just use a voice command...
Old Feb 22, 2026 | 10:20 AM
SilverEX15's Avatar
Voice command - right. What could go wrong? 😂
Old Feb 22, 2026 | 11:34 AM
bobski's Avatar
Has the switch had beverage splashed on it or anything?
I don't have a wiring diagram page that covers the MID buttons specifically, but the other steering wheel controls are wired in clusters. For instance, all the cruise buttons share a single signal wire back to the gauge cluster. They do this by connecting each button to a unique value of resistor. When a button is pressed, its resistor gets connected to the signal wire, the CPU in the gauge cluster sees the resistance and decodes it as its respective button press.
If the select button is crudded up, the button itself could be showing some resistance when pressed, when it should act more or less as a dead short. That crud-resistance would get added to the button's unique resistor value, making it look like a different button got pressed.
Old Feb 22, 2026 | 11:36 AM
SilverEX15's Avatar
Nope. The buttons are clean, and everything works except selecting the TPMS to reset it.
Old Feb 22, 2026 | 11:45 AM
bobski's Avatar
Is the warning light on? Have you tried ignition on, engine off? Ignition on, engine on?
Has the TPMS thrown a warning? If not, try deflating one tire (rear is probably safest) to ~15 PSI and then driving around the block to get the warning light on. Park, ignition off, air up the tire to its proper pressure, ignition on (engine on or off if it matters), trigger reset, drive the car on a straight road to finish the reset/relearn.
Old Feb 22, 2026 | 11:48 AM
SilverEX15's Avatar
Yes, yes, and yes. Maybe I'll try it again today. As long as I know the tire pressures are okay, I'm not concerned. Just annoyed.
I could bring it to the dealer and pay $2,500 for lots of new electronics, but I don't think I'll do that.
Old Feb 22, 2026 | 12:44 PM
bobski's Avatar
Have you gotten a list of the error codes?
Old Feb 22, 2026 | 12:47 PM
SilverEX15's Avatar
No error codes displayed, and I 'm not going to bother connecting the OBD II.
Old Feb 22, 2026 | 01:06 PM
bobski's Avatar
I'm not going to bother connecting the OBD II.
The GK TPMS is a function of the ABS/VSA unit. If your scan tool can read ABS codes, it should (in theory) be able to access TPMS codes, though it would depend on the tool's software to interpret them. Probably a C1xxx or C0xxx code.
BertZ
Dec 22, 2025 04:20 PM
oskie
Jul 11, 2023 12:32 PM
David Jenkins
Apr 30, 2021 10:06 AM
Phoebe70
Jul 15, 2015 05:54 PM
SilverEX15
Mar 18, 2015 01:56 PM
