Nice Rocker Switches
Old Aug 18, 2014 | 06:41 AM
SilverEX15's Avatar
Laser Blue has very nice rocker switches that I'm hoping will fit in the Fit. They are illuminated when turned on, and they are available for different purposes. I just ordered two: Power and LED Bar.
Amazon.com: laser blue switches: CDs & Vinyl
Old Aug 18, 2014 | 10:38 AM
tmfit's Avatar
I finally found the switches I was hiding from myself. :-/ the dimensions are 1.437 tall x .820 wide if you have an accurate way to measure the hole. Basically 1-7/16 x 13/16"
Last edited by tmfit; Aug 18, 2014 at 06:49 PM. Reason: Corrected 1.437 dimension had typed 1.347
Old Aug 18, 2014 | 04:53 PM
SilverEX15's Avatar
Originally Posted by tmfit
I finally found the switches I was hiding from myself. :-/ the dimensions are 1.347 tall x .820 wide if you have an accurate way to measure the hole. Basically 1-7/16 x 13/16"
Good. Those are the measurements I got. My switches should be here by the end of the week.
Old Aug 24, 2014 | 07:53 PM
Bassguitarist1985's Avatar
Do these fit in the openings to the left of the steering wheel?
Old Aug 24, 2014 | 09:25 PM
tmfit's Avatar
No they don't.
Old Aug 24, 2014 | 09:34 PM
SilverEX15's Avatar
I gave up on the rectangular switches and drilled 1/2" holes in two blanks covering the openings. I found the perfect switches for those spots. Now I'm trying to think of a use for the third slot.
Tomorrow I'll post details about how I installed the switches. Today I posted a how-to for adding a fuse plane under e dash.
Old Aug 24, 2014 | 10:52 PM
Cool keep me posted. Just ordered the parts for my LED chassis underglow kit. Gonna need a nice switch, or worst case connect the led controller to an ignition controlled bus and not an always on to prevent draining the battery.
SilverEX15
Mar 1, 2015 07:37 PM
SilverEX15
Aug 21, 2014 03:07 PM
ThEvil0nE
Jan 20, 2013 11:34 AM
TheRegulator666
Jul 25, 2012 05:02 PM
mintec
Jan 17, 2009 10:09 PM
