Aftermarket armrest/center console?
Old Aug 29, 2014 | 01:12 PM
Bengerm77's Avatar
Does anybody know where to get an aftermarket armrest or center console or whatever that thing is called? The stock one is way too low, and I want something I can really lean on.
Old Aug 29, 2014 | 02:28 PM
15BlkPrl's Avatar
As of yet there isnt anything out there for the 2015's. Giv it some time they will be out soon enough....
Old Aug 29, 2014 | 02:33 PM
JupiterJoe's Avatar
I haven't located any - but ended up making my own.... A piece of thin plywood or similar for the base, 4" of foam from Walmart, some black cloth from walmart, and a good staple gun along with some 1" black elastic bands to hold it in place over the existing armrest works pretty well... you can also make it any height you want from 1-4 inches by just adjusting the amount of foam you use. I made mine about 16 inches long and 6 inches wide.... Just typical stuff you can pick up at Walmart for < $20....
Old Aug 29, 2014 | 03:39 PM
Bigbadvoodooguru's Avatar
anyone notice that they made the armrest have that little corner cut off for no reason? They could have easily made it square and just hang over the parking brake. When pulled the parking brake it wouldnt even come close to the armrest. I have been throwing around a spacer idea in my head to raise the stock armrest a few inches, but I'll probably never get around to it.
Old Aug 29, 2014 | 03:46 PM
noripwr's Avatar
I got arm rest mods from amazon. I think they were called elbow friend. Works fabulous. Doesn't retain body heat either.
Old Aug 29, 2014 | 06:44 PM
SheepNutz's Avatar
What's funny about that cutoff is that it's supposed to be on the other side, giving the driver the extended part. That's how it is in the RHD Fit, they just never bothered to reverse it for LHD Fits.
Old Oct 1, 2014 | 09:05 PM
Bengerm77's Avatar
So I've waited a month, has there been any aftermarket console/armrest progress?
Old Oct 1, 2014 | 09:11 PM
Apexracing's Avatar
Am i the only one who likes the low arm rest? Makes shifting a mt much easier. My ep3 never had an arm rest and i loved it.
Old Oct 2, 2014 | 07:58 AM
cloud11244's Avatar
You can get center-console armrests in black color and 2 size options at Floor Mats, Car Covers, Cushions, and Parking Aids from Driving Comfort.. Amazon also has them in charcoal grey (less expensive than driving comfort). These attach with a strap that goes around the center console cover.
You can also get "elbow friend" on amazon which attach with velcro strips. I used these for the the plastic door arm rest.
Old Oct 2, 2014 | 03:49 PM
jjcentral's Avatar
[/QUOTE]
Could you tell how you attached the plywood to the existing setup? Also a picture from the open position would be great. Thanks.
DigitalDude65
May 2, 2019 04:39 AM
lomz
Aug 9, 2016 01:23 PM
oufink
May 23, 2015 02:08 AM
SilverEX15
Sep 1, 2014 12:00 PM
diskullman
Dec 30, 2008 02:40 PM
