Fuse Question
Old Aug 30, 2014 | 04:31 PM
SilverEX15's Avatar
Fuse Question
If I add one of these Add-A-Fuse things to an empty spot on a fuse panel, will it be powered? I know the car might have to be turned on, but would there be a power wire running to all those blanks?
Amazon.com: Pico 0956PT 10 Amp ATM Mini Blade Fuse Add-A-Circuit Fuse Holder: Automotive Amazon.com: Pico 0956PT 10 Amp ATM Mini Blade Fuse Add-A-Circuit Fuse Holder: Automotive
Old Aug 30, 2014 | 04:48 PM
rodney's Avatar
get a test light and check yourself.
i will be using an add a fuse for my sirius install. i have no idea where the fuses are, or what is free/used on the 15' fit. when i get a chance, i will look, but it should be self explanitory.
Old Aug 30, 2014 | 09:54 PM
SilverEX15's Avatar
For my XM I taped into the wire for the 12v outlet. I ran that wire to a separate fuse panel which I put under the left side of the dash. I connected the XM, GPS, and dash camera to that. For my sons car, I'd like to try tapping into the original fuse panel over the driver's feet - taking an empty slot. If that doesn't have power, I'll use a slot where there's already a fuse.
With the ads a fuse, you can use a spot where there is already a fuse. You put the original fuse into the holder nd then add the new fuse.
oneder101
Jun 15, 2015 05:03 AM
GotFitB13
Mar 9, 2015 08:22 PM
SilverEX15
Aug 31, 2014 09:25 AM
SilverEX15
Aug 25, 2014 08:29 AM
stock0891
Feb 20, 2010 04:06 AM
