Ridiculously hot map lights?
Old Sep 5, 2014 | 09:33 PM
spaghetina's Avatar
Has anyone noticed this? I turned my map lights on for ~5 minutes earlier, and by the time I turned them off, they had gotten so hot that I couldn't touch it for more than a second or two before my finger felt like it would burn.
Old Sep 5, 2014 | 10:26 PM
SieGunso's Avatar
is it the stock bulbs or did you replace with LED?
Old Sep 5, 2014 | 10:38 PM
exl500's Avatar
Map lights? To what are you referring...the overhead?
Old Sep 5, 2014 | 11:07 PM
hellgiver's Avatar
They are incandescent bulbs, of course they get hot. If you dislike the heat switch to LED bulbs.
https://www.fitfreak.net/forums/3rd-generation-2015/83738-how-guide-upgrade-interior-bulbs-led.html
Old Sep 5, 2014 | 11:23 PM
spaghetina's Avatar
I'm referring to the set of 2 overhead lights in the front of the car, by the sunroof button. I know that they're incandescent bulbs and that incandescents get hot, but I didn't expect them to get so hot that they made the plastic cover searingly hot to the touch. I've had covers in other cars get hot, but not THAT hot.
I've only had the car 2 days, so I haven't had a chance to swap anything out yet (nor am I confident that I'll be able to do it on my own anyway), but I've read the the LEDs are pretty intense for a bulb up front, where one's lighting needs are generally less than in the cargo area. Not sure I want to make that swap just yet, but thanks.
Old Sep 5, 2014 | 11:32 PM
sooznd's Avatar
I have maplights in my GE Fit and have even forgotten to turn them off & left on overnight (more than once)- still the oem bulbs and they do not get unreasonably hot-- something is not right, you should not have to replace the bulbs with led
Old Sep 5, 2014 | 11:40 PM
exl500's Avatar
Thank you for the clarification. No, they did not.
Old Sep 6, 2014 | 09:12 PM
morgantruce's Avatar
One of my pet peeves is ANY electrical device that can be easily left on all night long --- especially if the car does not beep and warn you as you walk away with your mind on other things. I feel much better knowing that when the key is in my pocket, nothing but the clock is running. Of course, with these new cars, there are probably at least four different computers busily at work all night long figuring out the day's milage, how much life is left in the oil, how fat a spark the engine will need tomorrow morning, and when to let you know that: Yes! ---that piece of plywood you ran over this afternoon DID have a nail sticking up through it and you're in for a very flat tire.
QuiGonQuinn
May 10, 2019 12:03 AM
White_GE8
Jul 14, 2011 08:03 PM
xonexlifex
Apr 19, 2010 03:41 AM
kevvur
20
Dec 6, 2008 03:29 PM
copilot18
Feb 13, 2008 02:15 AM
