Parking brake adjustment - 2015 GK with manual transmission
Old Apr 15, 2015 | 11:24 PM
bzdang's Avatar
Got my Fit in February, have 5000km on it and the parking brake lever/cable/whatever needed adjustment badly, but it wasn't obvious to me just where the adjustment nut was located. Somewhere inside the center console...
Summoning my inner cave-man, I discovered how to get the back of the console off (yank it off)...
Stick a 1/2" or 13mm deep socket in between the two cables
These bolt heads will get in your way
The adjuster nut is like the rear drum brake adjuster on a motorcycle (no surprise) and does not have or require a locknut, it just has to be adjusted in half turn steps
If you're not sure how much to adjust it, take it to a mechanic. Don't overdo it and ruin your rear brakes.
Old Apr 16, 2015 | 10:14 AM
Bassguitarist1985's Avatar
I approve this mod!
Old Apr 22, 2015 | 12:56 PM
Uncle Gary's Avatar
Should maybe be a "sticky"??
Old Aug 5, 2015 | 02:38 PM
roksta's Avatar
Agreed. Mine was really loose and the dealer told me the whole console had to be removed. I just did this myself in about 2 minutes thanks to this post.
cooper58
Feb 6, 2018 07:22 PM
RG129
Jan 3, 2016 06:14 PM
NewFitGuy09
Nov 22, 2011 07:13 PM
Quartz
Jan 15, 2009 09:18 PM
doctordoom
Oct 17, 2007 03:34 PM
