Accessory mode in EX w/ push start?
Old Apr 28, 2015 | 12:01 PM
threehz's Avatar
Hey folks, just got my new 2015 EX last night and its great! One thing I cant figure out -- how do you go from the engine running to accessory mode? Last night I wanted to turn my car off and finish a conversation in my driveway but hitting the button turned off everything. Is there a way to turn off the engine but not the power?
Thanks!!
Old Apr 28, 2015 | 01:48 PM
GoBucky's Avatar
Thanks!!
With the car not moving and the engine running and your foot on the brake, put it in neutral instead of park, then press the Start/Stop button. Don't forget to put it in park before you exit though.
Or if you want to put it in park immediately, then do as follows: With the engine running and your foot on the brake, put it in neutral, press the Start/Stop button, take your foot off the brake (make sure you're on level ground though, or it will roll), press the Start/Stop button again, put your foot on the brake and shift to park. Wow, that sounds a lot more complicated than it really is.
Old Apr 28, 2015 | 01:52 PM
threehz's Avatar
interesting... what happens if i put my foot on the brake, put it in neutral, hit the button and then shift to park? i guess i will find out later, but wow this was definitely a more confusing answer than i expected! thanks!
Old Apr 28, 2015 | 02:04 PM
GoBucky's Avatar
You can try it but I think it will only allow you to shift if the ignition is in Run mode, not Accessory mode. I know you can't shift out of Park if its in Accessory mode, maybe it will allow you to shift into Park though. Give it a shot.
Old Apr 30, 2015 | 08:32 AM
GoBucky's Avatar
Okay, so I tried this, and you are able to shift into Park, but doing this shuts everything down. You will no longer be in accessory mode, so if you are using your phone via Bluetooth, you will have to transfer the call from your Fit to your phone first before shifting to Park.
Michael Raymond
Nov 15, 2015 07:05 AM
winddancr4
Apr 13, 2015 08:33 AM
ai4px
Feb 25, 2015 07:02 PM
Padawan
Dec 18, 2014 08:13 AM
SheepNutz
Sep 25, 2014 11:03 AM
