Key not turning in ignition cyclinder
Old Jun 7, 2015 | 06:28 PM
Bronxborn's Avatar
Hello,
I just ran into this issue and posting this as a heads up for 15' fit LX (mine is a cvt) owners, for some odd reason when I put the key in the cylinder it is completely stuck. I cannot turn it at all. I just called road side assistance but they can only tow the vehicle to a dealer for mechanical problems.
This is very frustrating and disappointing. I only have 4200 miles on the vehicle so for something this weird to happen just blows my mind.
Old Jun 7, 2015 | 09:16 PM
DrewE's Avatar
Is this the ignition lock or the door lock?
If it's the ignition lock, sometimes that happens when the wheels are turned to one side and causing a torque on the steering column. The solution then is to pull the steering wheel in the direction the wheels are turned to ease up the force on the steering column lock.
Old Jun 7, 2015 | 10:16 PM
Bronxborn's Avatar
Unfortunately that wasn't the case . Most likely just something faulty that warranties will cover
Old Jun 7, 2015 | 11:19 PM
tbFit's Avatar
I assume you tried the other key?
Old Jun 9, 2015 | 03:41 AM
Virgo's Avatar
Sorry this may sound silly. But is your gear in P mode?
Old Jun 9, 2015 | 10:38 AM
Bronxborn's Avatar
The car was in park. The safety lock mechanism malfunctioned.
Jfit2009
Aug 6, 2020 03:22 PM
FitRaptor
Aug 30, 2016 07:24 AM
FitfulKenny
Dec 4, 2015 09:45 PM
Alanmite
Dec 16, 2012 12:08 AM
pr1970
Nov 17, 2012 07:52 AM
