Grill guard needed for GK ?
Old Jul 13, 2015 | 07:01 PM
Bossharp's Avatar
I have a PBP EX CVT and it's my first Honda. In researching the Fit I run into a common problem of air conditioning issues caused by rocks and road debris hitting the compressor or the lines causing leaks that was not covered by the warranty. In the redesign for 2015's was this issue addressed? Does the new Fit need a aftermarket grill guard to protect the air conditioning? Here in Florida it's critical to have it and I think it's the number 1 reason why people dump a car cheep because it is so expensive to get fixed. Is there any even on the market yet ?
Old Jul 14, 2015 | 07:05 AM
GoBucky's Avatar
I have not heard of this being an issue with the 2015 Fit. I don't recall ever reading about any complaints either. Was this a problem with the first 2 generations?
Old Jul 14, 2015 | 08:48 AM
Uncle Gary's Avatar
The GE fit had pretty large rectangular openings in the lower grill, and there were a number of threads about damage to the condenser from stones entering the large openings. Several people posted write-ups on DIY solutions (wire mesh, etc.).
The GK has much smaller hexagonal "honeycomb" grille openings, so I expect this shouldn't be quite the issue it may have been before. The openings are smaller, and the honeycomb shape should make the grille stronger (still plastic, of course). FWIW, I never had a problem with my GE, but then I don't follow other vehicles closely and am careful around road construction.
Old Jul 14, 2015 | 09:13 AM
SR45's Avatar
I live in Florida, and its not critical (Two generations of Fits as well). Never had one on any vehicle. Interesting question
Old Jul 14, 2015 | 01:15 PM
Bossharp's Avatar
Any vehicle can be improved but some do have weaknesses that need to be addressed by the new owner.For example I'm looking for a dual battery set up down the road to have a power inverter connected.At the very least up grade to a better, stronger one over the stock battery. Same with LED's for the interior lights. I'm glad to hear it's better grill with smaller openings since the Fit has such a low ground clearance.
majik808
Oct 18, 2011 08:49 PM
Spacecoast
Oct 8, 2009 10:35 PM
iKONA636
34
Mar 13, 2009 12:08 AM
ABuckFitty
Mar 20, 2007 12:53 AM
SilverNChrome
Apr 27, 2006 01:07 AM
