Rear toe out of spec
Old Aug 27, 2015 | 04:52 PM
Scotty2h's Avatar
Hello,
As part of my oil leak saga the dealer had to drop my transmission. After they did an alignment and I noticed that the rear toe is 0.39 vs spec of 0.24.
As I have learned our rear toe is not adjustable. They indicated I probably hit a pot hole or otherwise which knocked it out of spec.
I'm just wondering how big of a pot hole this would have been. Of course I've hit some, but not so large that I ever thought it would have damaged the car. If your average pot hole can knock it out of alignment then over the life of the car the toe must go to hell.
What are we talking about here impact wise to knock the toe out? normal pot hole or holy shit event where you check the car when you get home?
Some of my forum searching suggests this is an issue from factory but they don't really discuss how use might contribute.
Old Aug 27, 2015 | 05:05 PM
Bassguitarist1985's Avatar
Originally Posted by Scotty2h
....As I have learned our rear toe is not adjustable. They indicated I probably hit a pot hole or otherwise which knocked it out of spec. ...
Bullshit! The toe IS adjustable on the GK. It is adjustable on the first generation GD body too. The only generation where it is NOT adjustable is the 2nd generation GE body. It has welded hubs.
Anyways you can purchase an EZ Shim kit and make the adjustment to toe and camber as needed to get the wheel back into spec. A little toe isn't bad thus why Honda gives it a range up to .24 degrees. The closer to 0 degrees (straight ahead) you can get the better.
Check my video on my air shock mod, I wanted to see for myself the hardware I'd need to play with if I had to align the rear wheels myself. No dealer will fix the alignment for you, dont waste your time havign them try to. Some have tried and succeeded, the majority have lost this battle.
Odie
Nov 25, 2015 07:16 PM
hiwatt357
Nov 14, 2013 11:35 PM
AutoFit
Sep 12, 2012 07:55 PM
Stacey444
Nov 16, 2011 09:37 AM
piperpiperpiper
May 10, 2010 07:50 AM
