fascinating fit feature
Old Sep 1, 2015 | 07:14 AM
Press Fit's Avatar
Engineering genius or miscalculation?
Old Sep 1, 2015 | 09:42 AM
Wallygator's Avatar
Uh, I got nothin'
Old Sep 1, 2015 | 10:42 AM
KentFinn's Avatar
Originally Posted by Wallygator
Uh, I got nothin'
That makes at least two of us. Maybe a wider shot and some text would help.
Old Sep 1, 2015 | 11:00 AM
Press Fit's Avatar
Originally Posted by KentFinn
Maybe a wider shot...
It is our windshield wiper on the passenger side.
Old Sep 1, 2015 | 11:35 AM
exl500's Avatar
"Engineering genius or miscalculation?"
I'll go with engineering thoughtfulness. There are so many things on this car that are so well thought out.
Old Sep 1, 2015 | 12:09 PM
KentFinn's Avatar
Thanks for telling us. I'll go with styling and engineering. The last car I had (2008 Suzuki SX4) the passenger side wiper extended a little beyond the edge of the glass, not by much, but just enough to be noticeable. The Suzi was a good little car, but they didn't catch the little details. Honda still makes mistakes, nobody's perfect. Even million dollar Lambo's have faults.
Old Sep 1, 2015 | 01:26 PM
stembridge's Avatar
It's simply a way of getting a little more vertical coverage by the wiper - you'd be amazed if you were to stand a Fit windshield straight up. It's pretty long!
es
Fit Charlie's Avatar
Having every part of the blade always touching glass isn't important. Having it long enough to clear the glass you're looking through is. Losing an inch of overhang in the park position means losing an inch at the top and bottom of your field of view. Positioning the arms differently would be even worse.
Honda did it on purpose.
Old Sep 1, 2015 | 08:17 PM
Uncle Gary's Avatar
Such is life when your windshield is taller than it is wide. I'm sure this was the best solution to getting maximum swept area of the wipers.
Old Sep 1, 2015 | 08:33 PM
Bigbadvoodooguru's Avatar
Except I've been experimenting with that gap, and have filled it temporarily. I don't have enough time with it yet, but first impressions are the wind noise on that side is significantly less if I make it look like the drivers side. Not sure why it was needed to begin with...
VW's have a service position to change the wipers, but then tuck under the hood cowl out of the airstream to reduce wind noise and mpg (which having the wipers out of the way actually makes a significant difference)
I've been trying to figure out why the wind noise on the passenger side is so bad compared to the drivers side, which is at least tolerable.
Old Sep 2, 2015 | 07:50 AM
Extending the cowl to shield the wipers in the parked position is low on my to-do list. It is on the list, though.
It's more for snow accumulation than wind noise, though. So it's way low on my list.
Old Sep 2, 2015 | 01:06 PM
Carbuff2's Avatar
Neither....
How about: Tradition?
Our GD has a cutout area on the trim like that, as well.
TaubBaer
Apr 20, 2015 06:25 AM
strmslvrfit
Jan 7, 2015 11:17 PM
shawnshank
Oct 19, 2013 04:45 AM
carloso
Mar 9, 2010 07:18 PM
Howard Lester
May 4, 2005 11:16 AM
