How to remove the armrest piece that actually flips up
Old Sep 18, 2015 | 06:07 PM
trashercan's Avatar
Hi there, I want to know how to remove the piece that flips up and is attached to the top material of the armrest, it has a hinge that goes back into the centre console and I cannot work out how to remove it.
Thanks in advance...
Old Sep 19, 2015 | 05:32 PM
TorontoBoy's Avatar
I cannot help much but here's a parts diagram...
thread from replacing shift knob #19 by Apex Racing -> Hondaline Parts -> View large diagram
Link from SheepNutz:
breakout diagram from SheepNutz
Part #9 liike like a hinge that screws into part #18, the padded top
From Sheepnutz photo you can see the hinge screws on the sides, top back of the arm rest...
from SheepNutz. At the rear and top of the arm rest you can see a bolt for the hinge.
From the very top of this photo you can see the arm rest pivot bolts. You might just need to remove the rear plate to expose the bolts. Follow his thread but only remove the rear plate...
From SheepNutz, after removing the rear plate from the bottom, both sides. You can barely see the arm rest pivot bolts at the top...
Maybe this helps?
wackyflik
Feb 11, 2017 11:47 AM
korgster
Apr 15, 2015 02:26 PM
SilverEX15
Oct 19, 2014 04:47 PM
polokid69
Sep 5, 2012 06:35 PM
Ex-MA Hole
May 19, 2011 01:18 PM
