Reinforced Cargo Floor
Old Sep 28, 2015 | 03:26 PM
esnave09's Avatar
Has anyone else noticed that the trunk floor in our cars is not super tough? I only noticed because every week I have to load a 75+ lb sound board on wheels into my car, and now I have a definite crease in my floor. Has anyone tried to reinforce it, say with a sheet of metal or wood?
Old Sep 28, 2015 | 04:05 PM
2Rismo2's Avatar
I've thought about doing that as well. I borrowed a gas powered pressure washer from my friend. It gouged one of the little panels that folds with the rear seats.
I thought about using plywood and pvc tubing into the spare tire that adds support. Cover it in felt, though it'd be hard to match the floor fabric.
The thin cover just pulls off easily. It's held on by clips near the rear seats.
Old Sep 28, 2015 | 10:02 PM
carrier's Avatar
Do you think adding the cargo tray to the hatch floor would reinforce it or is that a waste? Couldn't hurt...?
Old Sep 28, 2015 | 10:10 PM
TorontoBoy's Avatar
The Fit is not a truck, though it might work like one. I don't think one of the design features was to load heavy 75 lb amps and sound boards. I'm going to build a plywood subfloor in order to dissipate pressure on any one spot. The carpet is cheap, the top surface of the cargo area is cheap, the "Fitruck" needs a little help.
Old Sep 29, 2015 | 10:16 AM
AFittingName's Avatar
I'd suggest getting a piece of plywood from HD/Lowes, cutting it to spec (if you don't have power tools at home, you can just bring in the specs and they'll cut it for you at HD), then buying a cheap rubber mat off of Amazon (10% the dealership price), and laying it on top of that plywood. Looks nice and will definitely protect the floor and spread out any concentrated weight. $25 solution.
I recently bought these:
Amazon.com: Heavy Duty 5pc Front & Rear Rubber Mats w/ Trunk Liner - All Weather Protection - Universal Car Truck SUV - Black: Automotive Amazon.com: Heavy Duty 5pc Front & Rear Rubber Mats w/ Trunk Liner - All Weather Protection - Universal Car Truck SUV - Black: Automotive
They are nice. Maybe not as high quality as the dealership ones, but they're $25 for the entire set, so.... not complaining. You only really need to cut out a notch on the front driver's side mat for the dead pedal.
Note if you use plywood, you should put something between it and the floor to protect the car, like a tarp or garbage bag or whatever. Otherwise it'll splinter and rub all over the fabric.
Old Sep 29, 2015 | 06:37 PM
esnave09's Avatar
I like this idea! Maybe I'm getting a little nitpicky, but how well does the trunk mat fit the cargo area (does it run up the sides at all?), and is it trimmable? I would want to find just the cargo mat, since I already have WeatherTechs up front, so I'll do some looking around...
Old Sep 30, 2015 | 12:18 PM
You can cut it to size with any sort of knife. It overlaps a bit. The mat is sold separately.
Markhagemann
May 6, 2015 11:45 AM
Foxhollow
Apr 27, 2015 12:57 PM
jmonroe
Mar 30, 2011 05:49 AM
pillboxhat
17
Jun 29, 2009 10:48 PM
Jontasmo
Jun 12, 2009 03:44 AM
