When to replace CVT fluid?
Old Jan 23, 2016 | 01:32 PM
DArkk's Avatar
Coming from 2012 Honda Civic Hybrid that I had to replace the CVT fluid at 30k miles which I did myself to save $135 dealership wanted to charge. I don't see this anywhere in the 2015 Fit owner's manual. All the manual talks about is have the dealer check the fluid level and replace if necessary.
Ok, just like any fluid in the engine it needs to be checked and replaced if necessary. I do all oil changes and fluid replacements myself so be nice to know when I should replace CVT fluid. Not sure if replacement is even necessary in this car other than checking and adding more fluid? Maybe at 100K miles? Any ideas?
Old Jan 23, 2016 | 03:00 PM
Dick W's Avatar
2015 Fit Maintenance Minder code 3 is "Replace transmission fluid".
Old Jan 23, 2016 | 08:42 PM
DArkk's Avatar
Yeah saw that but any idea when it supposed to come on? Any of you guys had the CVT fluid replaced yet?
Old Jan 24, 2016 | 08:35 AM
2Rismo2's Avatar
I'm assuming it'll depend on your driving style. Some people have 6500 oci, but I've been getting to 8500 before the MM comes on.
Old Jan 24, 2016 | 08:52 AM
Carbuff2's Avatar
Aside from engine oil, the other MM services come up at a mileage (closest to an oil change).
Old May 11, 2016 | 10:24 PM
Carsmak's Avatar
Honda typically recommend's 3yr interval on Brake fluid, and nothing listed on the MM.
Old May 11, 2016 | 10:52 PM
Jagged1's Avatar
Did mine at 53,000 miles when the 3 code showed.
666fit666
Dec 14, 2023 11:24 AM
SilverEX15
Sep 4, 2019 05:17 AM
ben_fit
Sep 7, 2018 10:06 AM
SilverEX15
Sep 27, 2015 03:58 PM
gmbdelsol
Mar 22, 2010 06:02 AM
