AMSOIL Full Synthetic CVT
Old May 24, 2016 | 01:48 PM
GeorgeL's Avatar
Originally Posted by Mainia
Here is an HRV but no pan on this one?
That's an HRV, but a 1st generation 2001 model, likely Australian market. Not much in common with the current Fit CVT.
Old May 24, 2016 | 02:14 PM
dwtaylorpdx's Avatar
No this is NOT a coin toss one bit. This has been done for 30 years by hundreds and thousands of car owners. I brought this up to the guy I work with on our oil analysis who in fact helped design Castrol's synthetic ATF. He said no issue there, that is how we do it. We cocktail all the time. You just use the same brand and oil base. (As my Redline cocktaiing).
I have a manual transmission that blew up twice,,, following red-lines advice,, on the second go around I pushed up the support chain and got a "oops" oh yea you have to run z instead of x in that particular transmission. And no they didn't offer to cover the cost their mistake. Basically I had a trans with brass synchs and the oil they told me to use wasn't compatible so they pitted to death.
I've also had oil congeal mixing the same brand but 2 quarts were a year old and 3 were brand new.. Bottles were identical. Not redline but...
Your friend is right they cocktail in the plant all the time, doesn't mean they don't make incompatible combinations.. Luck of the draw. Probably OK if your paying attention, but for the bazillion folks out there who don't rally have the base knowledge of what to look for,,, mixing oils is not the way to go. IMHO and everyone is entitled to their opinion.
Old May 25, 2016 | 05:32 PM
csb101's Avatar
Weekend
So after two drain and fills my cvt transmission is running A LOT better, but still has that weird hum/vibration, but its less. Im going to do another 54 dollar drain and fill this weekend with a write up and pictures. Its very easy.
Mehmet0001
Dec 7, 2018 10:17 AM
bosotncream
Dec 23, 2016 07:51 PM
Tha Dragon
Oct 22, 2014 05:28 PM
intiaz_k
Apr 26, 2013 06:50 PM
06Jazz
Sep 7, 2011 01:33 PM
