Larger fuel injectors
Old May 28, 2016 | 12:41 AM
Vjaramillo's Avatar
Has anyone done this upgrade or looked into it in order to get more performance out our our engines?
Old May 28, 2016 | 10:55 AM
KentFinn's Avatar
Not to discourage anyone, but it's more than just larger injectors. There has to be a balance ... better exhaust and the ECU for starters. There might be another 30-45 more horsepower there, but it has to be approached in a careful manner. I know that, and I'm as about as far from a mechanic/tuner as anyone can be.
Old May 28, 2016 | 01:58 PM
Vjaramillo's Avatar
Wow. Same number I read about doing my research. I wonder if anyone has done it.
Old Jun 1, 2016 | 08:42 PM
fujisawa's Avatar
I do not see much point. As far as I can tell the major limitation is the intake, which is quite roundabout with regards to airflow. Beyond that, you'll be adding a lot of noise, but still be limited by the throttle body opening. Fix THAT and maybe injectors would be an issue ... but I imagine the added power from a naturally aspirated fit would be minimal.
Old Jun 3, 2016 | 06:05 PM
BrucesFit's Avatar
Is this bigger injector for stock or modded or E85? Stock honda fit wont benefit, cause your not getting enough air to add more fuel. Heavy mod like a turbo or higher compression and bigger intake, throttle body, downpipe, highflow car, and catback would benefit greatly. Unless you want to run E85, which you need bigger injectors because you need to spray alot of gas. Regular gasoline need about 14.6 to 1 air to fuel for holding speed, while E85 need 9.8 to 1 air fuel ratio. While upgrading to bigger fuel injectors, you'll probably need a bigger fuel pump.(depends on your mods)
Old Jun 4, 2016 | 09:04 AM
kylerwho's Avatar
spoon fed
No I have not seen bigger injectors, however, if you take the injector to a diesel shop they will be able to bore out the nozzle thus creating a bigger cc injector.
As far as I have seen, everyone running boost is using a port injection setup.
K-tuner is working on a tuning solution for the motor.
cold air intake and fully open exhaust will help slightly give you more power.
Old Jun 12, 2022 | 02:18 PM
papsr's Avatar
if you want better gas mpg order the d set of injectors...im up to 49.8 mpg but system ltft shows -24 and cel is on wont pass inspection so back to a injectors and 38.5 mpg
Old Jun 25, 2022 | 07:18 AM
Z062FIT's Avatar
Civic injectors
I recently bought a set of civic x injectors for the L15B7. I'm running a stand alone ECU which can change the dwell time. That engine is rated at 205hp and people get it up into the 350s. I'm shooting for more than that so I'll be getting a port injection system designed to run along with the DI injectors during high demand...
Old Jul 23, 2022 | 01:45 PM
BMWguy22's Avatar
That should also wash away and carbon on the intake valves (common problem on the DI engines) and give better performance.
Old Jul 23, 2022 | 02:45 PM
Z062FIT's Avatar
Port injection benefits
Correct you are sir! We're planning to tune them to be always on at idle and up to 4,000 RPM just at like 5% duty cycle, constantly ensuring the valves have some atomized fuel on the back side. Above 4K they'll add fuel as appropriate...
Old Jul 23, 2022 | 05:06 PM
BMWguy22's Avatar
It would be awesome if there was a simple kit that owners could add on their car...for the FIT as well as other makes.
I'm sure once folks realized the benefits, they'd sell like hotcakes!
Old Jul 24, 2022 | 03:28 AM
Ukiyo.fit17's Avatar
Can the civic x injectors be ran in place of the stock injectors on a tune that’s using a normal cycle? Any advantages or disadvantages to this?
Pucci
16
Nov 4, 2015 09:50 PM
Spooling
49
Oct 11, 2015 10:19 PM
Myxalplyx
Oct 21, 2014 04:17 PM
bgravesmill
27
Sep 13, 2009 08:50 PM
blackgd3
Jul 10, 2007 11:33 AM
