How To: Fully disable traction control, stability control, ESC, VSA
Old Jun 1, 2016 | 02:45 AM
stealthpenguin's Avatar
Try this at your own risk.
The button on the left side of your lower dashboard is used to disable or defeat the traction and stability aids.
The manually only describes a process to partially disable traction and stability aids. I finally found a method to fully defeat traction and stability aids (ABS still functions).
Partially disable
Press to turn on, press again to turn off. This does not disable traction control in all instances.
Fully disable
1. Turn car on
2. Parking brake off
3. Press and hold brake pedal
4. Turn traction control on and off
5. Release brake pedal
6. Parking brake on
7. Turn traction control on and off
8. Press and hold brake pedal
9. Turn traction control on and off
10. Traction control light should be solid and another light blinking
Or, worded another way:
1. Turn traction control on/off with brake pedal on
2. Turn traction control on/off with parking brake on
3. Turn traction control on/off with brake pedal and parking brake on
4. Traction control light should be solid and another light blinking
Old Jun 1, 2016 | 08:33 PM
fujisawa's Avatar
What generation Fit?
Not that I'm going to try this. No point. For me. On a track maybe.
Old Jun 1, 2016 | 09:29 PM
This is for a third-generation (2015+) Fit.
Also, to clarify, this only temporarily disables traction control. Once you hit the button again or turn off the car the traction control is reenabled.
Fully defeating the traction control is necessary for autocross/track.
vinnimac
Sep 17, 2016 08:35 AM
simon696
Mar 10, 2011 08:06 PM
vwli
Dec 11, 2009 08:51 AM
90crxfreak
Mar 3, 2009 03:15 AM
willmax11
Jul 3, 2006 12:43 PM
