2016 Fit DX: Multiple Warning Lights, ABS, VSA and EPS
Old May 30, 2016 | 05:59 AM
MelR's Avatar
Driving on a muddy unpaved road, steering carefully around deep puddles, has resulted in my ABS, VSA and EPS warning lights coming on and staying on. Strangely, I see no error codes with either my Scanguage 2 or my Android based OBD reader.
Has anyone else seen this light show? (Seems like wheel sensor may be out to lunch?)
Does anyone know if there is something unique about the OBD port in the latest model that would render my code readers useless. They always worked well with my 2007 Fit.
Old May 30, 2016 | 09:23 AM
ezone's Avatar
OBD2 only deals with engine and transmission.
Those other systems are not part of OBD2, even though their communication lines are in the same diagnostic plug.
Look for damaged wheel speed sensor wires....If none found, take it to your dealership....Warranty?
Old May 30, 2016 | 11:29 AM
TorontoBoy's Avatar
Originally Posted by MelR
...my ABS, VSA and EPS warning lights coming on and staying on...
Has anyone else seen this light show? (Seems like wheel sensor may be out to lunch?)...
No, not all 3 and they do not stay on. In winter I can get the VSA to momentarily light by sliding the ass end of the Fit through a corner with speed and ample hand brake.
I also don't think this has anything specific to do with the DX model, as these systems are common to all Fits. It looks like you shook something loose. Go to the dealer and get a checkup.
Old May 31, 2016 | 05:28 PM
Kevin Evans's Avatar
Are you getting stuff in your intake?
I've had these lights come on when a dandelion seed got stuck on the MAF sensor in the airbox.
Old Jun 1, 2016 | 12:20 PM
MelR's Avatar
The word from Honda is "Bad ABS Sensor".
Thanks for the replies.
Old Jun 2, 2016 | 12:06 PM
Desmond Lamar MacRae's Avatar
Mine has these lights on because i accidentally yanked the ABS sensor ot one of the wheels when removing them. Check that ought.
der Mond
Oct 11, 2018 08:21 PM
addison415
Mar 29, 2017 12:36 PM
phoenity
Oct 20, 2016 05:39 PM
phoenity
Sep 22, 2015 04:03 PM
jimsmith101
Jan 11, 2014 04:26 PM
