Push button start doesn't (start, that is)
Old Aug 8, 2016 | 09:11 AM
Uncle Gary's Avatar
Over the past week, my '15 Fit EX MT has failed to start on three occasions. I get in the car, disengage the clutch (manual transmission), and press the start button. The dashboard indicator lights, radio and ventilator fan come on, but the starter won't engage. Instead, the green light on the "start" button comes on. Press the button again and the car shuts down.
One more point: when the car doesn't start, the "whirring" sound you hear when you push the start button doesn't occur.
Repeat this process two, three, ten times and the car will finally start, and it will be fine until the next time it malfunctions.
I've contacted the dealer, but their "expert" tech is on vacation and they won't be able to look at it until next week.
Anybody else had this happen, and, if so, what did it turn out to be?
Old Aug 8, 2016 | 09:36 AM
James Butler's Avatar
Not a betting person but my money would be on the clutch pedal interlock safety switch that operates when pedal depressed.
Let us know
James
Old Aug 8, 2016 | 09:38 AM
oiric2006@gmail.com's Avatar
I have the exact same model. It happens the first time i start the car in the morning or after a long inactivity, but in my case I just have to press on the clutch all the way and it starts on the second try. Never failed to start after I do this.
Old Aug 8, 2016 | 10:13 AM
Uncle Gary's Avatar
Clutch switch was my first thought too, but if that were the case the car would go into "accessory" mode on the first press of the switch, not "ignition on" mode.
Old Aug 8, 2016 | 10:47 PM
Fit_as_a_butchers_dog's Avatar
Have the same car, not the same problem.
Curious to hear how this gets resolved for you. Best of luck.
Old Aug 9, 2016 | 01:25 PM
KentFinn's Avatar
I HAD the same problem for awhile, dealer replaced the clutch switch after it happened to one of their mechanics. Problem solved UNLESS I don't push the clutch completely to the floor. I have short legs (long torso) and the car starts after I reposition my foot.
6 speed 2015 EX. The switch is essentially a piece of white plastic about as long as my thumb.
Old Aug 9, 2016 | 03:49 PM
Uncle Gary's Avatar
I located the switch yesterday while playing around with the car. It CAN be adjusted since it's on a threaded mount. That could be something you could try.
Old Aug 10, 2016 | 06:44 PM
Uskies's Avatar
I had the same issue awhile back, but mine ended up being the starter failing (19,000m). 6 speed also.
Old Aug 14, 2016 | 04:50 PM
Uncle Gary's Avatar
Only good thing I can report is that it's now malfunctioning about every fourth try, so it may be bad enough that the dealer can see it happen.
Old Aug 14, 2016 | 05:30 PM
i think u need to insert a quarter each time..?
Old Aug 14, 2016 | 06:35 PM
KentFinn's Avatar
Maybe a Quarter of an Inch to the soles of my shoes. (Short legs 24" inseam, long torso 5'6") Seats as far forward as possible, height of seat near perfect for the short hood (bonnet for the Brits).
Old Aug 14, 2016 | 11:06 PM
bach's Avatar
Me too. I was concerned in the early days that I might have a problem. But it never failed on the second try after I reposition so after a while I just chalked it up to a wimpy first try clutch smash.
Old Aug 15, 2016 | 10:22 AM
KentFinn's Avatar
My right foot was amputated when I was 14 to "correct" a birth defect ... messed up right leg, more than 6" shorter than left. There would probably be a better solution today, but I was born 11/27/1940.
I learned to drive a manual shift 1954 Plymouth (3 on the tree) than had 1st and 2nd so close together that 2nd was virtually useless.
Old Aug 18, 2016 | 12:51 PM
Uncle Gary's Avatar
I just got off the phone with the Honda dealer. They said the starter motor is bad. Apparently there is a dead spot on the commutator. Every so often the motor stops in that one spot and won't start next time.
The good news is they figured it out. The bad news is the starter motor is on "backorder", so no idea when this will be fixed.
This means that Uskies is our winner. To those of you who guessed "clutch interlock switch", thank you for playing and better luck next time.
Old Aug 18, 2016 | 01:06 PM
KentFinn's Avatar
Thanks for the info. If the problem becomes chronic again, I mention your solution. Crest Honda seems to listen.
Update: 10 months, 2 weeks later, it happens again about 8 more times. Old shoes w/thin soles once; new shoes with thicker soles, at least 7 times. The worst times was yesterday, car stalled on busy surface street (4 lanes) at 5 pm rush hour. After 20 or so minutes, it started (stepped on clutch AND Brake at the same time, 15 seconds each time).
It is the clutch switch, as it was the last time. Had car towed to dealer this afternoon at their expense (warranty). Miles still under 6k, can purchased 26 months ago.
Last edited by KentFinn; Jul 7, 2017 at 09:11 PM. Reason: Update Problem Reoccured
jrv784
Mar 3, 2021 07:25 AM
SilverEX15
Mar 26, 2018 07:51 PM
ai4px
Feb 25, 2015 07:02 PM
mvang001
22
Jun 7, 2013 10:14 PM
TOOL
May 26, 2009 03:56 AM
