Crack on plastic part of truck hatch
Old Aug 8, 2016 | 06:22 PM
Daniel Navia's Avatar
Went to close my trunk this afternoon, as per normal, as I do everyday, and I hear a snap sound. I look closer, and see right beside the honda emblem, there is about an inch or so crack. I pushed it back into place, but the crack is there, and I imagine it will get worse as i continue to open and close the door. I've attached a picture. I already have an appointment with Honda for Wednesday, as the car is well under warranty. Do you think they will give me hassle to repair it? A car that is not even a year old (2016 fit lx cvt) shouldn't
have this happen so easily. Its the cheap plastic above the licence plate on the rear. (not sure of the official name)
Old Aug 8, 2016 | 08:04 PM
Pinsnake888's Avatar
They shouldn't give you any problems since the car isnt that old and under warranty, I want to wrap mine in CF but I dont know how to remove it lol.
Old Aug 8, 2016 | 08:46 PM
TorontoBoy's Avatar
This is a known issue and others here have cracked theirs. Since you only have an inch crack you could try to remove it, add some CA glue to the rear of the plastic and then reinstall. You'll need to repair it before the crack gets longer. I don't recall the cost of the replacement part.
While this part looks and acts like a handle, it is fragile. I always close the hatch on the metal part of the door and not this plastic piece.
Old Aug 8, 2016 | 10:44 PM
Fit_as_a_butchers_dog's Avatar
You're not closing the hatch, otherwise it wouldn't have broken.
Old Aug 9, 2016 | 07:11 AM
2Rismo2's Avatar
I avoid using that piece to close the hatch since it's so fragile. Honda engineers put a little cutout on the inside of the hatch. Fits your hand and I use that to close the hatch.
Old Aug 9, 2016 | 04:21 PM
I closed the hatch the same as I have every single day since getting the car in November.
Seems likely that it would be a known issue, the plastic has always felt cheap and brittle since day 1. I'll see what the dealership says and go from there. I know its a very easy fix/repair, but I'd prefer the dealership to fix on principal. It's less then year old, and all doors are closed with ease and carefully. This shouldn't happen without force. Worst case, I can't imagine the replacement part being too expensive.
On a side note, does anybody know the actual part name of the plastic piece?
Old Aug 9, 2016 | 06:41 PM
BenQuick's Avatar
Rear License Garnish Assembly
74890-T5A-J12
$60
Old Aug 10, 2016 | 08:55 AM
CommanderSlug's Avatar
Mine cracked too, but because my buddy used the garnish to OPEN the rear hatch (he failed to actually engage the actual flappy latch that's used to open). My crack looks much worst than yours lol.
Old Aug 10, 2016 | 10:00 AM
74890-T5A-J12
$60
Thanks for that. I'll keep it noted for the future. Dealership is replacing at no cost. Ordered the part today
brunes
Dec 1, 2022 07:15 PM
gfrobe
Jul 30, 2017 11:02 AM
Snoodmaster
May 4, 2010 08:54 PM
Kwonye
Nov 20, 2009 01:16 AM
EXACTA
May 7, 2008 05:54 PM
