No power after radio install
Old Jun 14, 2017 | 10:24 PM
urngegoat's Avatar
Hi guys,
I added a powered sub and Sirius radio to my 2017 Fit EX today. After running all of the wires, I turned on the system and everything worked fine.
But when I went to push the head unit back into the dash, I lost power. Everywhere. I've checked all of the fuses I could think of and they all look good.
When I press the ignition button, I hear a relay click in the steering column and the push button lights up and the light flashes green. But that's it, nothing else.
Any ideas?
Old Jun 14, 2017 | 10:40 PM
fizzy99's Avatar
Hmmm. Assuming that you have your key fob in the card... Take the fob, and use it to press the start button.
Anything different happen?
Old Jun 14, 2017 | 10:46 PM
urngegoat's Avatar
fizzy99,
We have progress!! Using the fob I was able to start the car. I don't have radio power, and the interior lights don't activate with the door open, so I assume I must have blown a fuse. Any ideas which one?
Edit: It was the 'backup main' fuse under the hood. Swapped it out and now we're good to go. Thanks fizzy99!!
Old Jun 14, 2017 | 11:49 PM
fizzy99's Avatar
Awesome! Glad my suggestion lead to the fix.
Old Jun 15, 2017 | 05:05 PM
Spunkmire's Avatar
My car did this to me when I was installing a stereo. I took the ground terminal off of the battery for a little bit and then reconnected it and everything seemed to work fine after that and I didn't run into anymore trouble.
Have a good day!
s.gumbs@gmail.com
Aug 12, 2016 10:56 PM
chubbs899
Jun 7, 2015 09:41 PM
SilverEX15
Jul 30, 2014 01:58 PM
Kishore
Jan 6, 2013 03:36 PM
STOCKTREK
Jul 25, 2011 06:09 AM
