2017 Honda Fit Temperature Control Dial Problem
Old Nov 29, 2018 | 12:18 PM
Bassguitarist1985's Avatar
Here you guys go. Its not terribly hard to get to. I would suggest for the temperature dial, set it to cold, and with your fingers, pry the pinch clamp up and move the cable (pull) back from the damper arm. Then check for full motion. If this does not solve your problem, then there is an obstruction or damage with the dampers inside the air handler. Cheers
RealestFit
Aug 13, 2019 07:43 PM
fitinvancouver
Aug 10, 2017 05:07 PM
bradbowl
Apr 17, 2017 12:30 PM
imhavingafit
Apr 13, 2017 09:24 PM
KikeDiaz
Jan 13, 2017 01:48 AM
