valve adjustments for third generation Fit?
Old Aug 20, 2017 | 10:30 AM
amberd03's Avatar
Does the third generation Fit require valves to be adjusted at specified intervals?
Old Aug 20, 2017 | 11:17 AM
dwtaylorpdx's Avatar
Any valve train without hydraulic adjusting "lifters" or "followers" needs an occasional check/adjust and even some with hydraulics do. Fast spinning small displacement engines wont suffer from checking the valve lash. If it still specs it in the manual "when valves get noisy" I'd fall back to every 60 to 80 K ,,,,pop the valve cover and run the valves..
Old Aug 20, 2017 | 11:57 AM
amberd03's Avatar
Thank you for the advice. I appreciate your rapid response.
sunnyday
May 27, 2017 09:18 AM
doctor J
Dec 20, 2015 12:55 AM
icedmocha
Feb 9, 2015 05:58 PM
g fit
May 12, 2014 07:06 PM
z06dustin
Mar 29, 2010 10:54 PM
