Rear hatch
Old Jan 5, 2018 | 08:49 AM
hoopmatch's Avatar
Rear hatch
I have a 2015 Honda Fit that recently started to balk at keeping the rear hatch up after it has been opened and raised.
I use the Fit for a window washing business, so the hatch is up and down several times a day. Ergo, it's possible I wore out the struts that keep it open.
But perhaps cold weather in Michigan played a part, too.
Has anyone else had trouble with their hatches staying open (and up) in cold weather?
Old Jan 5, 2018 | 09:19 AM
2Rismo2's Avatar
It's been pretty cold in the mid-atlantic and I haven't had a problem with mine. Maybe there are some aftermarket ones that aren't too expensive versus the OEM.
On my 4Runner it the struts on the hatch have a harder time in the winter, but in the warmer months it doesn't have a problem.
Old Jan 5, 2018 | 10:37 AM
Carbuff2's Avatar
This is a common issue on cars that rely on gas-charged lift supports to keep their relatively heavy hatches open.
Both cold weather and wear are factors. (On my sports car, I joke that I can determine my garage temperature by the amount the hatch stays up!)
Since you need that hatch to open, I'd resign myself to replacing them as a maintenance item.
Old Jan 5, 2018 | 02:09 PM
Press Fit's Avatar
If it's not a warranty situation,
replace them yourself for $50 replace them yourself for $50
. I easily replaced them on my minivan. You don't want the hatch to crush anyone's hand.
Old Jan 5, 2018 | 07:05 PM
i was at -10F the other day and the GK's rear gate held up just fine.
Old Jan 6, 2018 | 08:25 AM
hoopmatch's Avatar
How to replace
Can anyone offer guidance on the method of replacing the struts?
Old Jan 6, 2018 | 08:35 AM
Press Fit's Avatar
Old Jan 11, 2018 | 08:09 AM
hoopmatch's Avatar
Thanks for your help, everyone. I wound up having a mechanic at my local Discount Tire install the lift gate struts. He did it in five minutes and didn't even charge me!
Old Jan 12, 2018 | 08:22 PM
awesome! good to hear happy endings.
Old Nov 2, 2019 | 12:18 PM
nomenclator's Avatar
2015 Fit LX... my struts no longer hold up the hatch in cold weather. I have a trick I use instead of buying new struts. I get a small hose clamp, the expensive kind with the little screw that you use to tighten it. I put it around the rod on one strut, lift the hatch, and tighten the clamp.When I want to let the hatch down, I give the screw half a turn and the hatch falls down.I keep a nut driver (it is like a screwdriver handle but with a 6 point or 12 point socket on the end instead of a screw driver blade) in the car to use to turn the screw that tightens-loosens the clamp.
I think maybe I got some oil on the rods and I wonder oil on rods got into the rubber seals inside the struts and caused them to deteriorate.
Old Nov 2, 2019 | 01:24 PM
fitchet's Avatar
The struts are wear items.
The OP admits greater than average use of the hatch due to his business. So I think 4 years, might just be normal wear.
I agree with just considering it's replacement as a part of normal maintenance issue. Assuming a good quality replacement, and it's at least another 4 years of a reliability.
Old Nov 4, 2019 | 11:09 AM
If anyone is interested, I started a thread in the third generation DIY section, here, about replacing the struts oneself.
Old Nov 4, 2019 | 12:05 PM
evilchargerfan's Avatar
posted in the other thread, but .... here is my "fix" for a bad hatch lift support:
hoopmatch
Sep 19, 2018 02:20 PM
shawnshank
Nov 29, 2017 04:36 AM
User1
Aug 3, 2017 10:33 PM
BMCBoid
Mar 5, 2016 10:25 AM
vickenp
Aug 1, 2013 11:47 PM
