Daylight savings time question
Old Mar 12, 2018 | 11:09 AM
SR14626's Avatar
I don’t know if it’s just me that made a mistake or not, but not having a GPS system unit, Saturday I changed the clock one hour up preparing for the daylight savings time on Sunday at 2 AM. Later on Sunday I noticed that my Clock was not at the correct time but another hour added. I thought my non-GPS system wouldn’t do this, only a GPS system would automatically change the clock. Did anybody else notice this? If not, then it was me that made the mistake.
Old Mar 12, 2018 | 11:23 AM
Fuelish's Avatar
My LX did not update the time, it still shows the time my house clocks are showing, 1 hour behind....guess I'll change 'em all today, perhaps
Old Mar 12, 2018 | 12:28 PM
SR14626's Avatar
Guess it was my mistake.
Old Mar 12, 2018 | 12:42 PM
woof's Avatar
This morning I went out to my 2018 LX, put the key in and turned the screen on, but didn't start the car. The time was wrong, still showing old time. Waited .... and about a minute later the time automatically changed and moved one hour up so that it's correct now. Looking around in the clock menu I see that there is a setting to automatically update for Daylight time if you want and I have it "on". Otherwise you'd have to do it manually yourself. I don't have GPS so I'm not sure where the Fit gets the time information, perhaps off radio station sub carriers which may carry that kind of info.
Old Mar 12, 2018 | 12:45 PM
Uncle Gary's Avatar
Is that new? I don’t recall any such setting on my ‘15.
Old Mar 12, 2018 | 01:05 PM
Fuelish's Avatar
Same here....
Old Mar 12, 2018 | 01:25 PM
Pumpkintacos's Avatar
On my 2018 EX I had to manually change the time to the correct one. I went into clock settings and "Daylight savings time" was ON, so I don't know why it didn't work.....I pressed ON again and it finally changed itself. Hope I don't have to do that again.
Old Mar 12, 2018 | 01:36 PM
woof's Avatar
You may have just been too impatient. On mine it didn't happen instantaneously when I turned the car on. I figured it took about a minute to happen but it might have been longer.
Old Mar 12, 2018 | 01:41 PM
Maybe, I didn't time how long I waited, but I just assumed it would've changed itself right away.
Old Mar 12, 2018 | 07:37 PM
QuiGonQuinn's Avatar
My 18 EX changed automatically. There's a setting in the clock menu to update it automatically or not
Old Mar 12, 2018 | 08:30 PM
fitchet's Avatar
Either way.
I don't mind if it sets itself.
Or I don't have a problem adding or subtracting an hour manually.
I think I've done it manually since I've owned the vehicle.
Old Mar 13, 2018 | 07:44 AM
Carbuff2's Avatar
What happens with me is that I forget to change the car clocks (because I don't have the keys on me when I'm adjusting all the other house clocks).
Days later, when I go for a drive, a few miles in I realize $%&$@%^ I forgot to change the time, and I start messing with it while on the road! (Distracted Driving)
Of course, someone else ALWAYS has it worse than us:
Attached Thumbnails Daylight savings time question-stonehenge-savings-time.jpg
Old Mar 13, 2018 | 03:28 PM
fitchet's Avatar
I wonder if this must be a new feature on the newer Fits?
I checked my owners manual for my 2016 Honda Fit EX and it doesn't seem to suggest there is any "automatic" way for it to adjust. Only how to change it manually.
So if the new Fits have a automatic way? That must be a change.
Old Mar 13, 2018 | 05:43 PM
woof's Avatar
The 2018 Fit got a minor mid term upgrade in a number of areas. Honda mentioned some of the major things like better soundproofing and the radio knob but there were probably a number of other small things done which they never mentioned and I guess this is one of them. There's probably a few other small things which Honda did on the 2018 which no one is aware of yet.
Old Mar 14, 2018 | 09:40 AM
SR14626's Avatar
Yes, on the 2018 model EX, there is an option in settings that you can turn on or off for daylight savings time. I’m guessing that it works off the radio station to get the proper time. Nice to have instead of having to buy the GPS system at a greater cost and using your smart phone for directions. $1000 upgrade GPS system is way too much.
Old Mar 16, 2018 | 10:02 AM
SoCalPurpleFit's Avatar
My 2015 EX will update the time automatically if and when it syncs to a phone using Bluetooth. I am sometimes out of town on work for several days at a time, and during these periods I disconnect my Fit's battery to avoid excessive drain. When I reconnect it, it lights up with the time on its factory default, but within seconds of the display showing that a Bluetooth connection to my phone has been established, the clock automatically starts to show the correct time. Without a phone to sync to, however, I have to set the time manually.
Old Mar 17, 2018 | 08:03 AM
that's cool info.
Old Mar 23, 2018 | 03:14 PM
BakeMan's Avatar
That's a DIY item.
NotMyName
Mar 29, 2023 10:12 AM
kakrohn
Apr 24, 2021 03:55 PM
Yinshaokie
Nov 21, 2018 09:12 PM
User1
Aug 28, 2018 02:51 PM
