Stupid low fuel light
Old Jun 20, 2018 | 10:05 PM
RealMTL's Avatar
I'm new to this car so the most I've ever had to fill is probably 9.5 gallons. I've only ever seen the gas light come on twice since owning my car.
Old Jun 20, 2018 | 10:10 PM
xxryu139xx's Avatar
The GKs low fuel light turns on at with 2 gallons left in the tank. Full tank is 10.6 gallons. You literally have anywhere from 60-80 miles before you truly run out of fuel.
Old Jun 21, 2018 | 08:14 AM
cgs2000's Avatar
If I had my way (NEVER happens!) the warning light would come on 'orange' at perhaps 2 gallons, then flashing 'red' and beep at 1 gallon. That setup would get my attention early on, then incite due panic when things got serious,
Old Jun 21, 2018 | 04:31 PM
evilchargerfan's Avatar
I just ignore that thing. I just look at my mpg (example, 40 mpg) and tell myself .... 10 gals @ 40 mpg = I should be able to go UP TO 400 miles on the tank
Of course, I do fill before that .... usually at the 9 gal mark. I'd like 1 gal in the tank to keep the fuel pump cool
Old Jun 26, 2018 | 12:18 PM
DArkk's Avatar
Conservative fuel gauge is on purpose as many of you have figured it out to prevent people from actually emptying the tank before refill and liability. Remember, this is designed for people who don't have common sense!
Alot of ways I wished the Fit had an actual 13 gal tank to go over 400 miles easily. 10.6 gal tank is just too small for my long daily commute. Ah well. It's what it is.
Old Sep 12, 2018 | 09:30 AM
michaelpersons's Avatar
In my brand new 18 LX, the very first time the fuel light came on I was approaching a gas station. I pulled in and filled up, it was 8.0 gallons.
Old Sep 12, 2018 | 09:48 AM
KentFinn's Avatar
So worst case you had at least another 60+ miles before you were actually out. That's a fair safety margin. Remember all the range, warning lights, and gauges go from WAG to SWAG … Wild Ass Guess to Scientific Wild Ass Guess, but they are all guesses.
Old Sep 12, 2018 | 10:36 AM
knope's Avatar
Never gone below 5miles remaining, though it's good to see i was far from needing to hike to a gas station.
Old Sep 12, 2018 | 11:25 AM
elkaku's Avatar
When the yellow indicator turns on on my 2017 lx it has always noted that there are 26 miles left to empty...... i once tokk it down to 5 but didnt risk it..... i have to check how much did i used to fill up... cuz i really have no idea
Old Sep 12, 2018 | 12:45 PM
wasserball's Avatar
I don't use the low fuel warning as an indicator (I estimate there is at least 2 gallons left in the tank). When the gas gauge shows no bar, I can go at least 6 more miles. The most amount of gas I have refilled is 11.33+ gallons. Be smart, use another way of determining the amount of gas left in the tank. If you don't like that amber light staring at you, cover it up with electrical tape. Please don't tell me that's bad for the fuel pump when the tank is empty, or topping off is bad for the environment.
Old Sep 12, 2018 | 03:21 PM
woof's Avatar
I've never understood this strange need to allow the gas tank to go down to nothing. I think I've yet to hit a quarter of a tank and almost always fill up when I cross the half way mark. Of course I have two gas stations within a couple hundred feet of me and have to pass them any time I'm coming or going so I guess that helps.
Old Sep 13, 2018 | 12:38 AM
  #32
wasserball's Avatar
holy smoke. let it be known that the less time you spend at a gas station, the more time you spend driving. I would prefer if I never have to fill the tank.
Old Sep 13, 2018 | 03:40 AM
  #33
craycraypixel's Avatar
Just the other day my low fuel light went on, said I had 35 miles left, averaging 32 mpg. I filled up roughly 8.5 gallons.
Old Sep 13, 2018 | 09:25 AM
  #34
LLLC1393's Avatar
Am I the only one concerned about saturating the charcoal filter int he fuel neck/filler by filling the tank as much as physically possible? From what I've heard over the years, you don't want to fill your tank until fuel is at the very top of the neck under any circumstances. When my low fuel indicator comes on, I try to fill the tank as soon as possible. It's such a small tank and I see no need to try and get the most fuel possible in at a time. In colder weather it's not a bad idea to keep the tank at least 1/4 full, if not more. You guys who are pushing it on low fuel level should consider what might happen if you find yourself in congested traffic unexpectedly. I've never run out of fuel and don't plan to, but imagine that it can be quite unpleasant to do so. Unless your fuel gauge is malfunctioning, running out of fuel is something that can easily be avoided.
Old Sep 13, 2018 | 02:44 PM
  #35
Shadow Smith's Avatar
There are definitely cars that will be damaged if you fill the neck all the way up. I don't know if the Fit is that way though -- but I stopped trying to jam gas into the car to get to the nearest "round number" years ago.
Old Sep 13, 2018 | 03:41 PM
  #36
Howie_Feltersnatch's Avatar
I'll run 30 miles less than the AMPG x10. So if my avg is 38.0 mpg, Ill drive to 350 before I fill it up, never put more that 10 gallons in it.
Old Sep 14, 2018 | 09:35 AM
  #37
marmaladedad's Avatar
How long of a commute do you have where 10 gallons is not enough?
On a side note, my in-laws live in Modesto so I am there quite frequently. We never take the Fit though - always the minivan.
Old Sep 14, 2018 | 10:16 AM
  #38
2Rismo2's Avatar
I've got an 80-85 roundtrip daily commute so about every 3 days I have to fill up. It would be nice to go a full week without filling up so I share the sentiment.
Old Sep 16, 2018 | 01:55 AM
  #39
Ahh, I see said the blind man, who picked up a hammer and saw.
My commute is 60 miles roundtrip, so if I am full on Monday, I can make it to Friday without having to fill the tank. One of my motorcycles that I used to commute on would get 90-100 miles a tank (small tank), so I was filling up every other day. That became old hat very quick.
fitchet
Dec 16, 2017 02:53 PM
fitchet
Jan 27, 2017 03:20 PM
Sean Passmore
Mar 9, 2015 12:12 AM
yeeman
Nov 9, 2007 04:58 PM
Ritzbury
Oct 30, 2007 01:49 PM
