TPMS failed to warn under inflation
Old Jun 4, 2018 | 07:00 PM
Originally Posted by 2Rismo2
I'd probably do a function check by filling up all tires to recommended pressures and resetting the TPMS. Then dropping the tire where you had the flat about 10-15 PSI and driving to see if an issue is detected.
DIY: how to prematurely wear radial potentially destroying sidewall permanently.
Old Jun 4, 2018 | 07:02 PM
Originally Posted by fitchet
Note to Self:
Stop car before checking tires.
haha!
Old Jun 4, 2018 | 09:54 PM
fitchet's Avatar
Originally Posted by wasserball
I am surprised that the tire did not come off the wheel.
If it was that bad, and the TPMS didn't illuminate? You might have a bigger problem than what I'e been talking about.
I'd probably want it checked out.
If your tire is so flat it almost comes off the rim?
Your TPMS should be illuminating.
Old Jun 4, 2018 | 10:01 PM
wasserball's Avatar
Well, it did, after I mounted the the wheel with the proper tire pressure from Discount Tires, 33 lbs.
Old Jun 6, 2018 | 09:17 AM
fitchet's Avatar
Yeah, but that's scary.
I hardly call it a working TPMS system if it doesn't illuminate as the tire becomes dangerously under inflated, but then ONLY illuminates once a good tire is re-installed.
You kind of want the opposite happening.
I want the system warning me a tire is bad....not "waking up" to tell me a new tire has been installed.
And I still think given the parameters of your situation as described? The TPMS should of illuminated.
Old Jun 6, 2018 | 09:39 AM
2Rismo2's Avatar
Working TPMS system or not, OP said they felt it drifting so should have pulled over and investigated. It would have probably saved the cost of a new tire.
TPMS system is a driving aid and shouldn't be relied on 100%. It's like blaming the autopilot when you crash your Tesla. Anything man made can fail.
Old Jun 6, 2018 | 12:26 PM
fitchet's Avatar
Who's saying rely on it 100%?
I even said, get yourself a good tire gauge because it's incumbent upon us as owners to check.
But I also think, especially on a newer vehicle, we should be able to expect that a system will work....as intended.
If it isn't I'd call that broken, and want it fixed. There are a LOT of things on a vehicle you can define as "driving aides" that doesn't mean I don't want or need them fixed if they break or aren't working.
DArkk
Jun 27, 2018 07:03 AM
ep3dan
31
Sep 28, 2015 07:24 PM
Brain Champagne
Jan 21, 2012 05:10 PM
RevToTheRedline
Aug 31, 2011 09:54 PM
goodyonsen
Apr 23, 2008 06:48 PM
