Replacing smart key?
Old Jun 4, 2018 | 11:37 AM
Joe Castanza's Avatar
Hello all,
Forgive me if this is a dumb question but is there a way to replace the smart key without having to deal with the Honda dealer? I’m not a “car guy” so I don’t know where to go for misc. items like this.
Old Jun 4, 2018 | 03:01 PM
marmaladedad's Avatar
I had a second key made and programmed for me by an independent locksmith. You will have to ask around though. I was able to find the contact info through my local mom and pop hardware store.
Old Jun 6, 2018 | 11:51 AM
Helios's Avatar
Yes, definitely. Even my Honda dealership uses an outside locksmith because their cost is lower. They still use OEM keys, just usually have more buying power versus a dealership. If I recall it was ~$120 for a replacement smart key on my 2018 from the locksmith, but the dealership wanted $126 just for the key itself, then additional to program it.
They had lost one of the original keys prior to me purchasing the car. They have the locksmith come once a week to do any key jobs. I was worried the key wouldn't be OEM, but that's not the case. I'd go with an independent locksmith. You will need your registration and ID for them to be able to prove ownership before they will program the ky.
Old Jan 12, 2021 | 11:25 AM
Jazu's Avatar
Normally most cars have the ability for you to have the key made BUT program it yourself (and that requires you to have one working current smart key). I'm not sure if Honda or another key company can ship you a pre-cut key if you give them the full key code.
How to Program Your Honda Remote in 9 Easy Steps
If you’ve recently bought a keyless remote entry fob for your Honda or the battery died in your existing remote, programming it is quick and easy. There’s no need to take the remote to a dealership for programming, simply follow these 9 simple steps.
A Step by Step Guide for Programming Your Honda Remotes
Step 1: Gather all the remotes. You only need one remote to access program mode, but all remotes must be programmed during the same session. Your Honda will “forget” any remote previously programmed.
Step 2: Sit in the vehicle with all the doors closed and unlocked.
Step 3: Turn the key to the ON position, one click before starting the ignition. The lights on the accessories should come on and the dash will light up.
Step 4: Within 5 second of turning the key to the ON position, press the LOCK button on your remote control transmitter for one second.
Step 5: Turn the key to the OFF position.
Step 6: Repeat Steps 4 & 5 two more times for a total of three ON/OFF cycles. Each step must be done within 5 seconds of the previous step.
Step 7: Turn the key back to the ON position (this will be your fourth turn of the key), press the “LOCK” button on your remote. The locks on your Honda will make a clunk noise exactly as they do when locking. You doors have not locked. This noise indicates your Honda is now in Remote Programming Mode. Do not turn the key off.
Step 8: If you would like to program more than one remote, press the LOCK button on each additional remote for 1 second. As with all other steps, you have 5 seconds to complete this step. Programming Mode will be activate for a total of 10 seconds. Only 3 remotes can be programmed to each Honda.
Your locks will make the clunking noise (as though the doors have locked) after each remote is programmed to indicate they have been successfully stored in the system’s memory.
Step 9: Turn the key to the OFF position and remove it from the ignition. Test all of your remotes to ensure they have been successfully programmed.
Remember that your remote will not work if the key is in the ignition. If you’ve lost your keyless entry remote, it’s a good idea to reprogram your Honda remote to protect your vehicle from theft.
RixAE86
Feb 21, 2019 01:43 PM
salamlaith
Jul 31, 2016 08:22 AM
SilverEX15
Sep 28, 2015 09:03 AM
demouser
Jun 15, 2014 05:53 AM
csteve21
Sep 2, 2009 06:54 PM
