Climate control issue
Old Jan 11, 2019 | 01:04 PM
SFL_Fit's Avatar
Anyone else have their climate temp knob stop working?
Old Jan 12, 2019 | 08:42 AM
Fuelish's Avatar
Might help folks who might know if you could define "not working" a bit more. Does it not turn???....or does it turn but not adjust the temperature?
Old Jan 12, 2019 | 08:50 AM
SFL_Fit's Avatar
if you turn the knob theres a crunching sound and the temperature isn't changing from cold to hot. I removed my glove box and looked under the dash. You can see the blue cable. When I rotate the knob to the max heat setting the cable for some reason wont extend long enough now. So I temporarily removed the cable from the actuator and moved the actuator as far forward as possible (heat)
Old Jan 13, 2019 | 09:36 AM
Bassguitarist1985's Avatar
Check out my video. It may help. Good luck!
https://youtu.be/5r_1d7xo388
Old Jan 13, 2019 | 09:51 AM
SFL_Fit's Avatar
I did the same thing what I've noticed is that my cable doesn't extend far enough to set the temp to hot. I'll post a video on YouTube later and place the link here.
andy342
Nov 18, 2024 07:24 PM
zQUEz
Nov 16, 2024 10:53 AM
nomenclator
Jun 25, 2016 08:49 AM
Lakeshore Fit
May 27, 2015 12:02 AM
qdn
May 4, 2005 11:16 AM
