Issue with cabin heat control.
Old Feb 8, 2019 | 07:16 AM
honestrands's Avatar
Since I bought my 17 lx I have had problems with the heat dial. First it was an adjustment of the cable. Next they replaced the cables. Next the dealer replaced the controll unit and the cables. Now I’m being told that it was just an adjustment again. The main problem is I either get cold or medium no matter how far it is on red.
Four times ive had to get this repaired and I feel like I’m plagued with this issue. I called the company to voice my concern and the rep said “I don’t know why you’re calling here”.
Has anyone else ever had an issue with the controls? My car has the three manual dials and not the touch screen.
Old Feb 8, 2019 | 10:00 AM
bargainguy's Avatar
An issue that is not fixed after repeated attempts is covered under lemon laws in your jurisdiction. Contact Honda Corporate directly. Tell them your concern, and that if the heating issue is not resolved to your satisfaction, you will be returning the vehicle to the dealership for a full refund. That should get their attention in a hurry.
Old Feb 11, 2019 | 04:36 PM
SilverEX15's Avatar
Two Fits, 130,000 miles total - no issues with the heating system - although I'd like it to put out more heat!
Old Feb 11, 2019 | 06:34 PM
Action Jackson's Avatar
The heater mix control is a mechanical device. The turning motion pushes or pulls a cable. The ends of the cable are attached to the dial or an adjustment arm (or whatever is used in the fit). The cable sheath does need to be attached firmly so that the cable can slide inside of it.
When I disconnect it on my Integra, the instructions were to simply adjust the dial fully one way, adjust the other end to where it's supposed to be, then secure the cable sheath to so that it retains that position.
Most of the problems that I've seen is when the cable sheath attachment comes loose.
I've never worked on this on my Fit, but by removing the glove box, I can see the contraption and might be able to work on this from there.
Old Feb 11, 2019 | 11:28 PM
Bassguitarist1985's Avatar
This video may help.
https://youtu.be/5r_1d7xo388
Old Feb 12, 2019 | 07:19 AM
SilverEX15's Avatar
Ah, that's your video! I was going to say that it's an unusually good YouTube DIY video. In so many of these, the camera is moving all around, out of focus, and the speaker is mumbling. Nice work!
That pinch clamp seems iffy. I'd prefer something more positive, like a screw or a bolt. It looks like you would pull that cable out, reposition it, and snap it back in. Is that locking piece plastic? Before I did any adjusting, I'd check the actual position of the thing that is moving to control the temperature. Maybe it's opening/closing far enough, but it's just not registering right on the control knob. I had that situation with a car a few years ago. I got hot and cold air, but the dash control was off by a bit. I left it alone.
andy342
Nov 18, 2024 07:24 PM
zQUEz
Nov 16, 2024 10:53 AM
SFL_Fit
Jan 13, 2019 09:51 AM
HondaFan75
Mar 14, 2016 12:51 PM
decknicianf
May 30, 2012 10:33 PM
