CRC Intake Valve Cleaner, where to spray
Old Jun 23, 2019 | 11:08 PM
Bassguitarist1985's Avatar
Exactly as it says. Which hose near the throttle body? Also how to rev the engine from the engine bay to get the cleaner in there? Figure start doing it when I do an oil change. I have a catch can and that has been working great. Highly recommended!
Old Jan 9, 2021 | 01:26 AM
BMWguy22's Avatar
Have you found which hose to remove?
I'm in the process of doing this on my Fit as well.
thanks in advance
Old Jan 9, 2021 | 08:03 PM
Not yet still waiting. :-(
Old Jul 12, 2021 | 05:59 PM
kittenbutt's Avatar
I have done this before, allow me to help.
Remove the PCV hose, the one literally on top of the intake manifold.
Make sure to block off the rest of the hose opening with something when sticking your straw through.
I used a small piece of 3/8" hose and two clamps to pinch it off and seal the vacuum.
Good luck.
Old Jul 12, 2021 | 07:12 PM
BMWguy22's Avatar
finally figured it out...was much simpler than I anticipated!
cheers!
Old Jul 19, 2021 | 11:13 AM
Make sure to block off the rest of the hose opening when sticking your straw through, or do what I did, use a small piece of 3/8" hose and pinch it off to seal the vacuum.
Good luck.
Okay perfect. Next oil change will do this with the wife as she holds the rpm at 2k while spraying. I haven't done the spray and im at 36k, but catch can installed since 16k. Want to keep up with the maintenance of the intake valves before I eventually need to walnut blast them.
Old Jul 19, 2021 | 09:06 PM
Action Jackson's Avatar
I use a torque wrench to keep the revs at 2k.
Old Jul 20, 2021 | 02:52 PM
Great idea!!!
Old Feb 5, 2022 | 04:16 AM
kittenbutt's Avatar
I push up the drivers seat and use the scissor jack from the trunk to keep the gas pedal depressed at 2k rpm.
Old Sep 29, 2023 | 10:36 AM
Ericspyder's Avatar
I've been watching Youtube about CRC intake valve cleaner. Some of them are PRO and CON. Are they really working? Should we do it every 15k Miles? Thank you for advices.
jhass
Apr 21, 2018 02:41 AM
Koi
Nov 29, 2014 06:04 PM
Fit4Flight
21
May 31, 2014 10:40 AM
bluerice
Apr 1, 2009 03:39 PM
Steve
Sep 12, 2005 09:30 AM
