Fuel injector parts
Old Jan 20, 2021 | 08:20 PM
Dotthedog's Avatar
Fuel injector parts
greetings, I am replacing the injectors on my 2015 Fit EX 91K
I have gotten Injectors, and Fuel pipe16010-5R1-315-305 injectors
16012-5R1-315 fuel pipe
That should be it for parts right?
I can use the same fuel rail?, that the injectors plug into
Old Jan 21, 2021 | 09:45 AM
Jared592's Avatar
Just curious: What happened that you need new injectors?
Old Jan 21, 2021 | 12:12 PM
Dotthedog's Avatar
I keep getting Check Engine Lights
P219A, P0420
I have only had the car for 2000 miles bought used..
I added an oil catch can, and plan on also pulling the intake manifold and cleaning the air intake valves..
The car occaisional stutters, so do both all at the same time
Old Jan 21, 2021 | 02:26 PM
woof's Avatar
There's also a throttle body gasket #17107-5R0-004 mentioned in Honda Service Bulletin 18-027
Old Jan 22, 2021 | 10:52 AM
Jared592's Avatar
91k is crazy low miles to be needing to mess with any aspect of the fuel injection system unless someone was messing around with it and broke something. Not knowing the whole situation, my inclination would be to return the car to stock and see if the issue still occurs. I say this just because something doesn't add up if you're needing to do this much work on a car this fresh.
Old Jan 22, 2021 | 11:17 AM
Dotthedog's Avatar
Thanks..
Last time I checked the car is stock, sure I added an oil catch cat..
Plan to scope the intake and if ugly clean it..
if it (The codes ) persists then onto the fuel injectors..
Old Jan 23, 2021 | 09:17 AM
tyrtill's Avatar
It’s almost certainly ugly I would plan on it. It’s not that hard to remove and I didn’t even have to replace the gaskets.
107k
Traveller
Dec 17, 2020 10:24 AM
Vash
Feb 2, 2018 08:34 PM
Principe1218
Jan 22, 2010 11:13 PM
azkikersfit
Sep 29, 2007 12:35 AM
