"Power Is On"
Old Sep 27, 2025 | 03:52 PM
Farrago's Avatar
"Power Is On"
2017 Fit. EX. When I turn off the car, this appears on the dash and stays light for a while before turning off. As I push the Start./Stop button to turn off the car, there is a slight buzzing/grinding noise that occurs for 3 or 4 seconds, and this light comes on. It will stay on for a while (an hour or so) and then goes away.
There is a symptom that may or not be related. When I start the car, Sirius does not start and the radio diverts to the FM setting. I've also had the radio do this while driving.
I disconnected my camera system to insure there is no sympathetic battery drain.
Given the short life of the 51R battery, I am going crazy.
Old Sep 29, 2025 | 11:47 AM
bobski's Avatar
Obligatory "have you checked all the fuses?" One of the always-on "memory" circuits could be out, making the head unit reset (try to eject a non-existent CD) every time the ignition is turned off and back on again.
Old Sep 29, 2025 | 06:13 PM
Farrago's Avatar
Thanks. I will run a fuse check.
Old Oct 5, 2025 | 02:01 PM
Farrago's Avatar
The problem turns out to be a short circuit in the starter lock.
Old Oct 12, 2025 | 06:59 PM
bargainguy's Avatar
You can drop in the larger 51R battery instead of the stock 151R. Typically the tray does not need modification.
I did this with my '16 LX a few years ago when I lived in the upper midwest and the winters were brutal. The extra CCA of the 51R does make a difference.
BadAnimal
Jul 19, 2023 12:48 AM
clp
Oct 15, 2021 05:32 PM
lewjac3
Apr 15, 2020 11:51 AM
SilverEX15
Aug 28, 2014 04:15 PM
