Oil change on the GK
Old Nov 5, 2014 | 04:12 PM
  #61
Fitmo's Avatar
Anyone use these Rhino Ramps with a 2015 Fit?
Old Nov 5, 2014 | 05:14 PM
  #62
Bigbadvoodooguru's Avatar
I always position my head in an area where there is enough room if the vehicle falls, even with jackstands... Crushed chest... survivable. Crushed head... organ donor.
Anyone use a Fumoto valve with this thing, or know the thread pitch/size?
Old Nov 5, 2014 | 10:26 PM
  #63
kaymack's Avatar
Always change my own, so I can see how this plastic shroud with many tiny screws will quickly become a PITA. Any idea what the downside would be of just leaving the shroud off? Less than 1mog? I may be willing to settle for 40 combined rather than the 40.5 I'm averaging now just to reduce the tediousness of an oil change. I'm at 40% oil life right now.
Btw, for the 5 qt. Mobil 1 at Walmart, I usually reach for the "extended performance" label, as its only a few bucks more and supposedly contains more of the slick additive (proprietary moly?). It's supposedly good for 15k, but I still change at 5k with Mobile 1 extended performance filter (hopefully they're producing those for the GK at this time).
Old Nov 5, 2014 | 10:29 PM
  #64
DArkk's Avatar
I have those (older version) and seems it will work just fine. My old 2012 Civic Hybrid is lower to the ground than the Fit so shouldn't be a problem.
Just scary part of getting the car onto the ramp but I never overshoot it so it's fine.
I am going to get jack stands as somebody suggested as a safety measure.
Also those ramps will hold up alot of weight. It held up my old 2009 CRV just fine.
Old Nov 5, 2014 | 10:36 PM
  #65
DArkk's Avatar
I don't recommend leaving the shroud off the car even tho it's PITA. Because the oil filter is road facing so any debris might puncture it so there goes your engine. Oil change at 5K miles? Honestly, it's recommended at 10K-12K miles now with these cars. Follow the maintenance minder and it will save you money in the long run.
Been doing that ever since Honda added it with 2006 Honda Civic.
There is a story floating around that Honda will ONLY change the oil filter every OTHER oil change. That part I didn't like so I always change it with every oil change.
Old Nov 5, 2014 | 10:56 PM
  #66
kaymack's Avatar
Thanks for the valuable info... maintenance minder and shroud off and back on..got it, ugh
Old Nov 5, 2014 | 11:30 PM
  #67
Odie's Avatar
3 qts. + 1/4 qt. + 1/2 qt. = 3 + 3/4 qts.. . The '11 + '13 Fit take 3.8 qts.. Thus 3+3/4 to the line . No ?
Old Nov 6, 2014 | 10:00 AM
  #68
m_x's Avatar
m_x
I think more than MPG, the shroud is there to protect. This morning I was on the highway and a truck blew a tire a few cars ahead of me. It was a retread (which should be illegal because they blow out all the time and form huge, steel-banded pieces of death) so it just peeled into pieces. I missed it with the wheels, but it went under the car. When I got to work, the shroud has some big gouges taken out of it. No other damage though.
I'm glad the shroud was in place.
Old Nov 6, 2014 | 12:25 PM
  #69
GeorgeL's Avatar
Some creative person could hinge the panel at the rear edge with a quarter-turn latch or two at the front edge.
Old Nov 6, 2014 | 12:34 PM
  #70
DArkk's Avatar
Not sure how this shroud is mounted but on my old hybrid it was slide and then held by screws.
So yeah maybe a simple latch might work. Would have to be high quality stainless steel so it wouldn't rust as much like normal steel.
Old Nov 12, 2014 | 06:51 AM
  #71
rodney's Avatar
NO. 3 qts + .5 qts = 3.5 qts.
or you can do it this way:
3.25 qts + .25 qt = 3.5 qts
1 qt + 1 qt + 1 qt + .5 qt= 3.5 qts
.5 qt + .5 qt + .5 qt + .5 qt + .5 qt + .5 qt + .5 qt = 3.5 qts
5 qts, drain 1.5 qts = 3.5 qts...
the main thing here is the car has a different engine then previous gen fits, which required less oil.
Old Nov 12, 2014 | 07:26 AM
  #72
Fitmo's Avatar
Originally Posted by rodney
I won't let ya down
1 qt + 1 qt + 1 qt + 0.25 qt + 0.125 qt + 0.0625 qt + 0.03125 qt + 0.03125 qt
or said another way...
1 qt + 1 qt + 1 qt + 8 oz + 4 oz + 2 oz + 1 oz + 1 oz
Old Nov 12, 2014 | 07:34 AM
  #73
Justin Lane's Avatar
First you say this:
yep, on the nose. i put 3 in it, started it, then put 1/4 quart, then half quart in, and it was right on the upper line.
drainplug was in the area with the circle...
Then you say this:
See the confusion???
Old Nov 12, 2014 | 05:59 PM
  #74
rodney's Avatar
yea, oops, i fugged up... i edited that a few times, and i guess i forgot where i left off.
it is 3.5 quarts. i am 50% + 50% sure of this.
Old Nov 21, 2014 | 09:25 PM
  #75
GotFitB13's Avatar
On the handful of cars I've done oil changes on I've never seen an oil filter installed on an angle like that. I suppose the new filter can be partially filled with new oil before putting it on. I liked that about our Forester, the filter was installed facing "up" so it could always be filled. Then it doesn't have to fill when starting the engine.
Old Nov 22, 2014 | 08:43 AM
  #76
rodney's Avatar
the angle of the filter does not matter. it pressurizes quickly and fills up in a few moments. having worked for a long time in the automotive industry, there are many oil filter locations/angles. horizontal and even upside down (which is the best for making large messes when doing an oil change...).
Old Dec 16, 2014 | 01:51 PM
  #77
NotMyName's Avatar
when to get first oil change?
I have had my 2015 LX CVT since late August, and have 4100 miles on it. The oil % display says 50%, but I've had friends recommend that I just get it changed at 5000 to play it safe.
How accurate is the oil life %? I'm planning on going to Valvoline when I do get it changed. Any recommendations on type of oil. Is synthetic the way to go?
Old Dec 16, 2014 | 02:05 PM
  #78
cab0053's Avatar
Do it when the MM tells you to or at the year mark whichever is first. There is currently break in oil with extra stuff in there that helps with longevity of the engine (at least with the gd and ge, I'm assuming they would use it for the gk as well).
What type of oil is a different story, with plenty of agruments. My only advice is to checK the oil level after its changed and read your manual. Lazy mechanics that don't read the specs will over fill.
Old Dec 16, 2014 | 04:15 PM
  #79
spreadhead's Avatar
Old Dec 16, 2014 | 06:06 PM
  #80
ROTTBOY's Avatar
Originally Posted by cab0053
Do it when the MM tells you to or at the year mark whichever is first..........
Solid advise!!!
Oil technology has changed much in the last 2 decades. They last much longer so the 3 - 5k mandatory change is a thing of the past - as long as you don't drive on dirt roads, daily.
Am getting close to 2k and it shows 80%. Will wait for the meter to show 10% or less then make the change. The Mobil 1 and Purolator filter are awaiting!!!!
