Door panel/speakers
Old Dec 30, 2014 | 11:31 PM
Snake's Avatar
Door panel/speakers
Hi all - new member, but I've been a lurker for a while.
I see that there are a couple of posts about getting the door panels off of a 15 Fit - but I'm stuck and can't seem to get the panel off completely. I was hoping someone who's done this successfully would be able to share any photos or better tips?
I've gotten the screw under the window switches, and the one in the door handle - from what I gather at this point I should be able to lift the door panel up and out, starting from the bottom? That's where I'm stuck - the thing won't budge, and I've broken one trim tool trying to pry it out.
Thanks for any advice folks may have!
Old Dec 31, 2014 | 05:13 AM
DOH GE8's Avatar
yep should just pull off now, was a little tight because the clips are still new
Old Jan 4, 2015 | 10:38 AM
kotarou's Avatar
The Clips are really tight.
I suggest to start from the bottom.
Hera an Image to have an idea where the clipas are:
Old Jan 4, 2015 | 10:46 AM
Snake's Avatar
Thanks! I was able to get the door panel off - you're right, it was super tight on there. I thought I must be missing something, and was worried about snapping something - but it finally popped off!
Old Jan 4, 2015 | 10:51 AM
kotarou's Avatar
That's Great.
I broke 2 Green Pins on my removal. But it's fine.
If you are going to do something with audio I suggest you to measure it first. (With the Windows Down
Something like I Did here:
Connector View
fatfetfitfotfut
Feb 17, 2017 12:35 AM
TWGE08
Jan 2, 2009 03:31 PM
badself
Sep 22, 2008 11:32 PM
HEMI-Fit
Nov 11, 2007 10:58 PM
dbagnulo@gmail.com
Aug 26, 2005 05:31 PM
