Ready to test/starter "beeps"
Old Nov 11, 2015 | 11:41 PM
Tom Spahr's Avatar
I have everything installed/wired. I wanted to test everything to ensure it's operational before cleaning up the wires and reinstalling everything. At the moment, the front seat is out, the connections for the hazard light switch and airbag "display" (just above the hazard switch), and all the 12VDC/USB/HDMI are disconnected.
When I reconnected the battery terminals and try to go into accessory mode, I get the green light on the start button flashing, and a series of beeps. Is this due to the connections that I've disconnected?
Old Nov 12, 2015 | 09:40 AM
Bassguitarist1985's Avatar
Yes, the USB, HDMI 12VDC plug panel has a connector for a receiver device (antenna basically) to detect the key fob. With that disconnected the car will not start at all. You need to reconnect it before you can proceed. Common issue, most people don't realize when they start pulling connectors.
Philip May
Aug 8, 2017 02:29 AM
Sean McKenzie-Mardelli
Oct 14, 2016 03:02 PM
wzlfit
Mar 30, 2016 07:52 PM
KikeDiaz
Oct 15, 2015 09:23 AM
manbat39
Aug 4, 2005 05:30 AM
