The Stembridge Fit (Jazz) Mod Thread - 2015 MSM EX CVT
Old Oct 2, 2017 | 11:47 PM
  #121
vic831's Avatar
Originally Posted by jhn
Is that Moog shim or SPC? Looks like Moog I think
I hate to bother you but did you ever figure out the exact torque specs for the rear axle hub to beam axle 4 bolts. I saw 61 ft/lbs on a drawing for an earler model fit. I bought the preindexed Moog toe shims 0.1- 0.5 degrees, they make a different indexed shim for the camber adjustment. They look like a gasket with the 4 bolt holes around the outside. I ordered them $6.60 each from rockauto. You can fit up to 2 shims per hub. They say to torque factory spec plus 10%, but what is factory spec? thanks in advance if you can help me. Answer per factory website is 47 ft/lbs plus 10%. !!!!!!!
Old Oct 3, 2017 | 06:33 AM
  #122
vic831's Avatar
Originally Posted by stembridge
Thanks. Since there are no shop manuals out for the GK yet (that I know of - other than the expensive subscription service, which I don't have), I used the TLAR* method, and they seemed to snug down evenly and with no apparent problems. The alignment will tell!
Thanks for the tip on camber, too. My autoxing coworker (Miata) recommended starting with -1.0°, but I'll go ahead and use -1.7° and see how it goes. The shop I use does some resto and rod work and should be cool with a custom alignment.
es
* "That Looks About Right"
The 4 12mm (14mm head) bolts have factory spec 47 ft/lbs torque. My moog instructions for the preindexed black gasket looking shims said add 10% to that so 52 ft/lbs for my application
Old Oct 3, 2017 | 08:46 AM
  #123
stembridge's Avatar
Ah, looks like you found the specs - great!
es
Old Dec 6, 2017 | 01:48 AM
  #124
edspecR's Avatar
hey this thread was pretty cool, most build threads aren't as concerned about being helpful :P
grats on the SS! awesome car
Old Dec 6, 2017 | 03:04 AM
  #125
USDM's Avatar
Congratulations on the new ride!
Old Dec 6, 2017 | 08:11 AM
  #126
stembridge's Avatar
Thanks! I had a lot of fun with the Jazz/Fit, for sure... the SS is quite a different beast, and I’m really enjoying it, too. I’ve put over 22K miles on it since April.
es
Old Dec 14, 2017 | 08:20 AM
  #127
gordata's Avatar
Good job on documenting all these mods in this thread.
Old May 19, 2018 | 04:57 PM
  #128
ItsKrisWithAK's Avatar
I can only go by "seat of the pants," but I would say it does feel a bit snappier. (c:
It's weird, but the exhaust sounds a bit raspier to me after adding the intake, which I like.
es
Did you get any CEL when you installed
Old May 19, 2018 | 05:08 PM
  #129
stembridge's Avatar
Nope.
es
Old May 19, 2018 | 05:22 PM
  #130
Nope.
es
Thank bro, glad you're still active with this community
Old May 30, 2018 | 01:31 PM
  #131
evilchargerfan's Avatar
I miss stembridge already
Old Mar 26, 2019 | 01:10 PM
  #132
I followed stembridges steps, and removed steering wheel. after reinstalling new wheel, 3 lights lit up ... can anyone help me brain storm some possible outcomes?
-vol controls works
-cruise control works
-I do remember installing the horn black connector
-I do remember installing the 2 connectors on the back of air bag
-I do remember reinstalling the screw for that grounding wire
Old Mar 26, 2019 | 04:43 PM
  #133
stembridge's Avatar
Wow, no idea here. Those lights (other than maybe the power steering one) would not seem to have anything to do with anything on the steering wheel. Hope you figure it out! If you have an ODBII scanner, you might see if it sheds any more light.
es
Heitor Terças
Apr 27, 2016 11:04 PM
Fitmo
Jun 2, 2015 09:39 PM
Chewee
Mar 17, 2015 03:20 AM
Master_Scythe
Nov 7, 2009 07:34 AM
kenken
Apr 10, 2008 11:16 PM
